generic operator with class(*) behavior question
Patrice_l_
I am wondering how does the generic operator works in case of an abstract class with a class(*) argument. The following code show an example, and the operator on the abstract class do not call the defined operator of intb even though the dynamic type is intb.  Any thought on such design ? A solution will be to override lower_than in intb like that rocedure,private :: lower_than => lowerthan_intb with a class(*) and then do a select type. But i thought that if the dynamic type was intb then the generic function will find lowerthan_intb.
module tata
implicit none
type,abstract :: b_type
        class(*),allocatable :: b
        contains
                procedure,private :: lower_than
                generic,public :: operator(.lt.) => lower_than
end type
        type,extends(b_type) :: intb
        contains
                procedure,private :: lowerthan_intb
                generic,public :: operator(.lt.) => lowerthan_intb
        end type
        interface intb
                module procedure :: intb_constructor
        end interface
contains
function intb_constructor(i) result(a)
        type(intb) :: a
        integer :: i
        allocate(a%b,source=i)
end function
function lowerthan_intb(a,b) result(r)
        class(intb),intent(in) :: a,b
        logical :: r
        print *,'lowerthan intb'
        select type(i1 => a%b)
        type is(integer)
                select type(i2 => b%b)
                type is(integer)
                        r=i1<i2
                end select
        end select
end function
function lower_than(a,b)
        class(b_type),intent(in) :: a
        class(*),intent(in) :: b
        logical :: lower_than
        lower_than=.false.
        print *, 'operator lower than class* no implementation'
end function
end module
program foo
use tata
implicit none
type(intb) :: d,d2
class(intb),allocatable :: cd,cd2
class(b_type),allocatable :: b1,b2
d=intb(1)
d2=intb(3)
allocate(cd,source=d)
allocate(cd2,source=d2)
print *,d<d2
allocate(b1,source=cd)
allocate(b2,source=cd2)
print *,'b1 extends btype to intb',extends_type_of(b1,d),same_type_as(b1,d)
print *,b1.lt.b2
print *,b1<b2
print *, cd<b1
end program
Patrice_l_
Should the compiler gives an ambiguous error in this case ? (gfortran does).
Also , what is the answer to extends_type_of(b1,d),same_type_as(b1,d), ifort says  T T, but gfortran says F T. Since the dynamic type is the same i think it should be true.
FortranFan
I think so, my read of the Fortran 2008 standard suggests your lower_than and lower_than_intb do not satisfy the generic disambiguation rules:
Patrice_l_
I agree with your reading FortranFan, since it will match class(*) and class(intb) at the same time. Then do you agree that extends_type_of(b1,d) should return T ?
FortranFan
Yes, I think extends_type_of(b1,d) must return true based on what the standard says:
Looking at the definition of extension type (same type or an extended type), the result should be true, I think.
Steven_L_Intel1
I have escalated the missing error about ambiguous interface as issue DPD200371156.
