getcwd line break 80 characters
Martin_D_1
Dear All,
I'm using the getcwd function on Ubuntu Linux and the return string contains a newline statement if the current directory name is longer than 80 characters:
program myWD
 use IFPORT
 implicit none
 character(len=1024)           :: cwd
 integer                       :: error
 error = getcwd(cwd)
 print*, trim(cwd)//':'
end program myWD
will give
 /nethome/storage/raid4/m.diehl/DAMASK/testing/Spectral_parsingArguments/referen
 ce:
/nethome/storage/raid4/m.diehl/DAMASK/testing/Spectral_parsingArguments/refere:
if I call the program from the folder 'reference' and 'refere', respectively. Tested with ifort 13.0.1 and 12.1.2.
Martin_D_1
sorry, formatting didn't work:
[fortran]program myWD
use IFPORT
implicit none
integer ::error
error = getcwd(cwd)
end program myWD
[/fortran]
will give
[bash]
ce:
[/bash]
Martin_D_1
I've investigated and figured out that it's just a formatting problem and every line will break after 80 characters. The underlying reason was, that my directory detection never works but with the help of
http://software.intel.com/en-us/forums/topic/274704
it now does. For gfortran, I can simply use the directory + '/.' and check for file existance
