29277 Discussions
problem with derived type I/O on internal file
johnyb_
I am trying out the derived type i/o available since version 14 of the compiler and running into problems when reading from an internal file. With the following code:
[fortran]module m_prb_dtio_1
    type t
        integer :: a
    contains
        procedure :: fmtread => t_read_formatted
        generic   :: read(formatted)  => fmtread
    end type t
    contains
        subroutine t_read_formatted(dtv, unit, iotype, vlist, iostat, iomsg)
            class(t),           intent(inout)   :: dtv
            integer,            intent(in)      :: unit
            character(len=*),   intent(in)      :: iotype
            integer,            intent(in)      :: vlist(:)
            integer,            intent(out)     :: iostat
            character(len=*),   intent(inout)   :: iomsg
            read(unit, fmt="(i2)", iostat=iostat, iomsg=iomsg) dtv%a
        end subroutine
end module m_prb_dtio_1
program test
    use m_prb_dtio_1
    character(len=100) :: str
    integer ios
    type(t) :: t1, t2
    str =  "42"
    open (10, file="test.input")
    write(10, fmt="(A)") str
    rewind(10)
    read (10, fmt="(DT)", iostat=ios) t1
    print *, "ios:", ios, ", t1 :", t1
    read (unit=str, fmt="(DT)", iostat=ios) t2
    print *, "ios:", ios, ", t2 :", t2
end program[/fortran]
The output is :
[plain]C:\>ifort prb_dtio_1.f90
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 14.0.2.176 Build 20140130
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:prb_dtio_1.exe
-subsystem:console
prb_dtio_1.obj
C:\>prb_dtio_1
 ios:           0 , t1 :          42
 ios:          48 , t2 :           0[/plain]
As far as I understand the standard, derived type I/O should work for internal files as well. As I have no other compiler that supports this at hand, I can not be certain if the error is in my code or a bug in ifort
Johny
P.S. I posted this already once a few hours ago, but the post did not appear.
This is our bug. It is fixed for a release later this year.
johnyb_
Thanks Steve,
So i'll have to wait a bit before playing with that new feature
