29375 Discussions
how to get the fast operation for derived type. a comparison test show optimization do nothing
Li_L_
module constants
    integer,parameter:: ip = 4
    integer,parameter:: rp = 8
end module constants
module vector_
use constants
implicit none
    private
    public:: vector
    public:: operator(+),operator(*)
    type::  vector
        real(rp),allocatable,dimension(:):: vc
    contains
        generic::           init    =>  init_ar
        procedure,private:: init_ar
    end type vector
    interface operator(+)
        procedure::  vplus
    end interface
    interface operator(*)
        procedure::  svproduct
        procedure::  vsproduct
    end interface
contains
    pure subroutine init_ar(this,ar)
    class(vector),intent(out)::         this
    real(rp),dimension(:),intent(in)::  ar
        this%vc = ar
    end subroutine init_ar
!----operator
    elemental type(vector) function vplus(lhs,rhs) result(vvp)
    type(vector),intent(in)::   lhs,rhs
        vvp%vc = lhs%vc + rhs%vc
    end function vplus
    elemental function svproduct(lhs,rhs) result(vr)
    real(rp),intent(in)::               lhs
    type(vector),intent(in)::           rhs
    type(vector)::                      vr
        vr%vc = lhs * rhs%vc
    end function svproduct
    elemental function vsproduct(lhs,rhs) result(vr)
    real(rp),intent(in)::               rhs
    type(vector)::                      vr
        vr%vc = rhs * lhs%vc
    end function vsproduct
end module vector_
program test
use constants
use vector_
implicit none
integer(ip)::   i,n,j
real(rp)::      t1,t2,t3,t4,t5,t6,t7
type(vector)::  p1
real(rp),dimension(:),allocatable:: p2
real(rp),dimension(100):: p3
    p3 = 1.0001d0
    p2 = p3
    call p1%init(p2)
    n = 1e7
    !1
    call CPU_TIME(t1)   !2.375
    do i=1,n
        p1 = p1 + 2.d0 * p1
    enddo
    !2
    call CPU_TIME(t2)   !0.297
    do i=1,n
        p2 = p2 + 2.d0 * p2
    enddo
    !3
    call CPU_TIME(t3)   !2.5
    do i=1,n
        call op(p2)
    enddo
    !4
    call CPU_TIME(t4)   !2.531
    do i=1,n
        p3 = p3 + 2.d0 * p3
    enddo
    !5
    call CPU_TIME(t5)   !2.515
    do i=1,n
        do j=1,100
            p3(j) = p3(j) + 2.d0 * p3(j)
        enddo
    enddo
    !6
    call CPU_TIME(t6)   !0.234
    do i=1,n
        call op(p3)
    enddo
    call CPU_TIME(t7)
    print*, '1',t2 - t1
    print*, '2',t3 - t2
    print*, '3',t4 - t3
    print*, '4',t5 - t4
    print*, '5',t6 - t5
    print*, '6',t7 - t6
contains
    pure subroutine op(s)
    real(rp),dimension(:),intent(inout):: s
        s = s + 2.d0 * s
    end subroutine op
end program test
here i test the operation of arraies, and three kinds of array are chosen
1. the derived type vector which is actually an array
2. the allocatable array with undetermined size
3. the array with determined size
and then 6 kinds of procedures are tested, which are all dealing with (s = s + 2.d0 * s )
then i find the difference time cost for each procedures
for O2, we get the time cost: proc1(2.375s), proc2(0.297s), proc3(2.5s), proc4(2.531s), proc5(2.515), proc6(0.234)
for O3, proc1, proc2, proc6 unchanged time cost, and proc3, proc4, proc5 decrease to 1.25s around
so i have a question: is it possible to get the speed as the proc6 for derived type with overriding operation?
how to do it?
Steve_Lionel
I have no idea, other than to make two observations:
  1. Each time a new, significant language feature was added, it took time for compilers to learn how to optimize them well. Consider array operations vs. DO loops.
  2. Any time you defer information to run-time, you lose performance. KIND type parameters are fine - those are always compile-time. But LEN parameters have been nothing but trouble for compiler implementors.
My advice would be to file a report with Intel and ask that the performance degradation be investigated. Maybe it's something simple, but don't get your hopes up too much.
Roman1
I hope you know that your test causes a floating point overflow.  Was that intentional?  When doing these kinds of benchmark tests, I don't think it is appropriate to have values set to Inf, or Nan.
Also, can you add a print statement at the very end, such as  print*,p3(1).  Since the array is not accessed at the very end, the optimizer might to something "smart", and remove its calculation.
Roman
Li_L_
Roman
thanks for your correction. i realized my mistakes after my post, so i have another test
program test
use vector_
implicit none
integer,parameter:: ip=4,rp=8
integer(ip)::       i,n
real(rp),dimension(:),allocatable:: p,pp
real(rp),dimension(:),pointer::     e,ee
type(vector)::                      q,qq
    allocate(p(100),pp(100))
    p = 1.001d0
    pp = 0.d0
    n=1e7
    !the fastest i know
    call CPU_TIME(t3)
    do i=1,n
        call op(p,pp)
    enddo
    call CPU_TIME(t4)
    print*, t4 - t3
    call qq%init(pp)
    call q%init(p)
    call CPU_TIME(t1)
    !e   =>  q%ptr()
    !ee  =>  qq%ptr()
    do i=1,n
        qq = qq + q + 2.d0 * q
        !call op(e,ee)
    enddo
    call CPU_TIME(t2)
    print*, qq%vc(1:10)
    print*, t2-t1
contains
    pure subroutine op(s,ss)
    real(rp),dimension(:),intent(in)::  s
    real(rp),dimension(:),intent(inout):: ss
        ss = ss + s + 2.d0 * s
    end subroutine op
end program test
here i post the fastest and slowest procedures. the second time cost is 10 times as the first time cost
i once changed the vector as wrapper of determined size array, like (real(rp),dimension(100):: vc)
then the calculation is around 2~3 times as the fastest procedure
so i realize the <allocatable> attr in operator function is manly responsible for the extra time cost
and more, i guess the pure function in Fortran is not as fast as inline function in C++ (ps: just guess, and i know little about C++)
i feel fortran lacks optimization for derived operator of derived type, or i lack some knowledge of fortran? i don't know.
i rewrite my code and let it compute under native data type and array.
any suggestions about the derived operator function is welcome
Roman1
When you do the second test (qq = qq + q + 2.d0 * q) , there are temporary array variables created at each operator function call.  If I remove these calls, the test would look something like the following code.   If you run it, you will get similar time values to what you had before.  As you can see, all of these allocations, deallocations and array copies are slowing the program down.
type(vector):: v1,v2,v3
    p = 1.001d0
    pp = 0.d0
    call qq%init(pp)
    call q%init(p)
    call CPU_TIME(t1)
    do i=1,n
       allocate(v1%vc(size(q%vc)), v2%vc(size(q%vc)), v3%vc(size(q%vc)) )
       v1%vc = 2.d0 * q%vc
       v2%vc = q%vc + v1%vc
       v3%vc = qq%vc + v2%vc
       qq%vc = v3%vc
       deallocate(v1%vc, v2%vc, v3%vc)
    enddo
    call CPU_TIME(t2)
Li_L_
    p = 1.001d0
    pp = 0.d0
    call qq%init(pp)
    call q%init(p)
    call CPU_TIME(t1)
    do i=1,n
       v1%vc = 2.d0 * q%vc
       qq%vc = v3%vc
    enddo
    call CPU_TIME(t2)
that's the point!
as far as i know, there exists many derived operator in C++, and no one complaining the speed
so the question: is there a similar way to construct derived operator in Fortran which avoids temporary containers
or Fortran discourages the derived operator for derived type
you know, it's mentally hard to recover operating polynomials to dealing with native array.
polynomials is a special allocatable vector, and we always want to see the expression:   a = b + c,  other than: a%vc = b%vc + c%vc, then round(a)
jimdempseyatthecove
If your derived operator in C++ is operating on objects that are a container with variable capacity, then you will see similar allocations for temporaries.
shorthand: associate (a=>oa%vc, b=>ob%vc, c=>ob%vc)
a = b + c
end associate shorthand
Jim Dempsey
Andrew_Smith
Valued Contributor I
The parameterized derived type should theoretically address your issue. However these are the run times for your last test program run on 64 bit and latest windows compiler:
Optimization level Fixed size (100) Allocatable Parameterized
O2 0.81 3.3 25.4
O3, IPO 0.53 3.3 26.5
Web master: The above looks like a table when I edit the reply form but displays as a simple list when posted.
You can see the long run times for parameterized types. This is the first time I got to try this new feature and I am dissapointed by the performance. It should be close to the times for the fixed size array.
Here is the full code I used for the parametrized derived type. I made no attempt to tune it (data alignment, explicit vectoring etc.) but I doubt any tuning is going to fix it.
module constants
module vector_
   use constants
   implicit none
   private
   public :: vector
   public :: operator(+), operator(*)
   type :: vector(n)
      integer, len :: n
      real(rp) :: vc(n)
    contains
        generic :: init => init_ar
        procedure, private :: init_ar
    end type
        procedure::  vplus
    end interface
    end interface
contains
    class(vector(*)),intent(out) :: this
    real(rp), intent(in) :: ar(:)
    this%vc = ar
end
elemental function vplus(lhs,rhs) result(vvp)
    type(vector(*)),intent(in) :: lhs
    type(Vector(lhs%n)), intent(in) :: rhs
    type(vector(lhs%n)) vvp
end
   real(rp),intent(in) :: lhs
   type(vector(*)),intent(in) :: rhs
   type(vector(rhs%n)) :: vr
   real(rp),intent(in) :: rhs
   type(vector(lhs%n)) :: vr
end
end module vector_
program test
   use vector_
   implicit none
   integer(ip)::       i,n
   type(vector(100)) :: q,qq
   p = 1.001_rp
   pp = 0.0_rp
   n = 10000000
   !the fastest i know
   call CPU_TIME(t3)
   do i=1,n
      call op(p,pp)
   end do
   call CPU_TIME(t4)
   print*, t4 - t3
   call qq%init(pp)
   call q%init(p)
   call CPU_TIME(t1)
   do i=1,n
   end do
   call CPU_TIME(t2)
   print*, qq%vc(1:10)
   print*, t2-t1
   pause
contains
end
end program
Li_L_
a = b + c
Jim Dempsey
part1: i'm not familiar with c++, maybe i made a mistake
part2: that partly solves the problem, but it looks not elegant :(
Li_L_
Optimization level
Fixed size (100)
Allocatable
Parameterized
O2
0.81
3.3
25.4
O3, IPO
0.53
3.3
26.5
module constants
module vector_
   use constants
   implicit none
   private
   public :: vector
   type :: vector(n)
      integer, len :: n
      real(rp) :: vc(n)
    contains
    end type
        procedure::  vplus
    end interface
    end interface
contains
    this%vc = ar
end
end
end
end module vector_
program test
   use vector_
   implicit none
   integer(ip)::       i,n
   p = 1.001_rp
   pp = 0.0_rp
   n = 10000000
   !the fastest i know
   call CPU_TIME(t3)
   do i=1,n
      call op(p,pp)
   end do
   call CPU_TIME(t4)
   print*, t4 - t3
   call qq%init(pp)
   call q%init(p)
   call CPU_TIME(t1)
   do i=1,n
   end do
   call CPU_TIME(t2)
   print*, qq%vc(1:10)
   print*, t2-t1
   pause
contains
end
end program
impressive test...
i know this type for the first time
what is the parameterized derived type designed for, with a so poor performance...
Andrew_Smith
Please raise this as a support issue for the performance of parameterized derived types. I would have expected performance somewhere between the fixed size and the allocatable vectors, not an order of magnitude slower! There really was no point in providing it like this.
Andrew_Smith
Blatent bump
Kevin_D_Intel
I have been looking at it Andrew. I'll get it to Development soon.
(Internal tracking id: TBD)
Andrew_Smith
Any progress please?
Was the idea of the parameterized derived type just an academic exercise or was it a serious attempt to introduce a unique performance benefit to the language?
Steve_Lionel
Performance benefit? No. Indeed there are several on the standards committee who have recently expressed the opinion that this feature should never have been added to the language.
Andrew_Smith
That is very dissapointing news. From snippets of conversations over the last few years I was under the impression that parameterized derived types would give improved opportunities for stack memory allocation and vectorization compared to allocatable vectors. I was hoping they would get near the speed of fixed size vectors since the performance loss from allocatable vectors is large (6x in my test above).
But why is the performance 10x slower again than allocatable vectors? If this is expected then they are pretty much useless in a high performance language
Steve_Lionel
jimdempseyatthecove
Li L:
The text of the general message on this forum is a variable pitch font. To get a fixed pitch font, Click on the {...} code button, select Plain Text, and enter/paste in your text.
As for performance, consider experimenting with specifying the vector bounds in the operation
   vr%vc(1:rhs%n) = lhs * rhs%vc(1:rhs%n)
and the same for the other functions.
Jim Dempsey
Andrew_Smith
Using my posted example I tried Jims suggestion and got no improvement.
Then I tried /Qhost and got a speedup of 0.15s for the fixed size vector and 0.3s for the parameterized derived type. This still leaves a whopping 25s discrepancy. Can Intel explain why this is?
jimdempseyatthecove
Andrew,
In the example #9, I notice that the "member" functions are declared elemental, however the usage is as scalar (iow not array of type(vector)).
What happens when you remove "elemental" from the derived type functions?
Jim Dempsey
Andrew_Smith
No significant change without elemental
Devorah_H_Intel
Please submit the ticket via Online Service Center for further investigation.
Thank you,
