29487 Discussions
how to get the file path for Fortran code
carlos8410
I'm using the TCL/TK code to call an execute file which is written by Fortran code.
I don't know how to exchange the data between these two languages. So I do it through the data file.
When the TCL/TK code generates a project, it will write data to a file with a specific extention inside the project folder. And it calls the Fortran code to read the file and do some calcation. The problem is how to assign the path of the data file to Fortran code. Because every time when a project is generated, it may have different path and different name. And the Fortran code needs to know the path of the project so it can read the data file inside the folder.
Is there any way to solve this problem? I don't have much experience in Fortran.
P.S. I'm using the Intel Fortran Compiler 10 (Windows).
anthonyrichards
New Contributor III
If you cannot touch the fortran code, then you are stuck I think. You have to copy the data file to where the Fortran executable is stored, or else copy the fortran executable to where the data file is located.
However, If you have the source code and can compile it, then you need to modify it to call the IVF routine(or in my case, the CVF routine GETARG)that gets the command line used to start the Fortran program. Then when you invoke the new program add the full-path datafile name as an argument on the command line. The program can then pick up the datafile and carry on as you want it to.
Quoting - carlos8410
carlos8410
Yes, I can modify the Fortran code.
But when a project is generated, the user already specifies the path and the name before calling the fortran code. So if the user needs to input the path again on the command line, it is not very user friendly.
I hope to find some way that can pass the path to the fortran code automatically.
If what you want is to find the location of the running executable, you can do that. You can then use that to construct the path to the data file. First you call the Win32 API GetModuleHandle with an argument of NULL to mean the current running program, and then GetModuleFileName to get the name of that file.
However, if the application will always be run from within Visual Studio, you don't need any path at all, as the default is the project folder.
anthonyrichards
New Contributor III
You say the user 'already computes the path to the file', in which case it should be available to be used as an argument to the command that starts the executable, no?
Exactly how does the user start the executable?
Paul_Curtis
Valued Contributor I
If your program is invoked as "myprog.exe", then the following Windows API will recover the complete path to your executable:
[cpp]
CHARACTER(LEN=256) :: fpname
INTEGER :: nc
!   get local root path from opsys; nc returned as
!   stringlength of total path
nc = GetModuleFileName(GetModuleHandle('MYPROG.EXE'C),   &
fpname, LEN(fpname)) [/cpp]
carlos8410
what I want is not to find the location of the running executable, but let the Fortran code know the path of current project, so it can read the data from the data file through the path.
And the application is not run from within Visual Studio.
I try to pass the path of the file as an argument to the fortran code. But I can't because TCL/TK and Fortran can't pass value through argument.
I paste part of my fortran code below to make my question clear.
At the beginning of the code, I need to read data from the data file. And the file is located inside the project folder.
Like the bold line below gives the path of the file. And (D:System FileDesktopGIDm1.gid) is the project folder.
But with the specified path here, the code can only read data from this file. If the user create projects using different path or name, the code doesn't work. Because it can't find the correct data file by using the path below.
PROGRAM MAIN
IMPLICIT REAL*8 (A-H,O-Z)
ALLOCATABLE :: X(:), XBASE(:), XOPT(:), XNEW(:), GQ(:), D(:),
1 FVAL(:), PQ(:), HQ(:), VLAG(:), W(:), XPT(:,:), BMAT(:,:),
2 ZMAT(:,:)
OPEN ( 15, file='D:System FileDesktopGIDm1.gidinput.inp' )
READ (15, *) N,NPT,IPRINT,NPTM,NF,NP,NDIM,NH,IDZ,KOPT,KNEW,
1 RHO_FLAG,JUMP_FLAG,FLAG_310
Les_Neilson
Valued Contributor II
Did you see the reply from Paul Curtis?
I don't know TCL/TK but at the point in the TCL/TK code that runs the fortran program you should be able to append the name of the data file.
e.g. in fortran you would write :
command = program_name//' '//file_name
iret=system(command)
I don't know what the TCL/TK code would look like.
Then in your Fortran code you wouldCALL Get_Command_Argument(1, ...)
which would give you the file name.
Les
Les_Neilson
Quoting - Les Neilson
Sorry, I meant Anthony Richards
Les
anthonyrichards
New Contributor III
Can TCL/TK create/modify a Windows Reistry entry? If so, then create a registry key and place the full path to the project there.
it is straightforward to modify the Fortran code to read the relevant registry key and obtain the path to the data file.
anthonyrichards
New Contributor III
Quoting - anthonyrichards
Something like
package require registry
registrySet "HKEY_CLASSES_ROOT\TclScript\YourProgram\ProjectFolder" (arguments here) ?
Carlos,
The program has no idea where the project folder is. There is no information available to it that would give that. All it knows is where the executable is. If that was created in a project, then it is likely that the project folder is one level up in the folder tree, which you can get by appending .. to the executable path (without the filename).
Note that if you call GetModuleHandle, you can pass NULL as the first argument instead of the executable name.
