29487 Discussions
how to pass complex array to dummy argument of REAL array type?
geotarget
how to pass actual argument of complex to a dummy argument of type REAL in windows
intel fortran
following code compiled and runs OK on Linux but won't compile in Windows intel fortran!
intel visual fortran compiler error message:
Error: The type of the actual argument differs from the type of the dummy argument. [TEMP]
COMPLEX
TEMP(*)
CALL
MYTEX (TEMP, 2, N1, SIGN, INIT, TAB1, IERR)
which was defined as
SUBROUTINE
MYTEX (C, IC, N, IDIR, INIT, RTAB, IERR)
REAL C(1);
REAL RTAB(1);
INTEGER IC, N, IDIR, INIT, IERR, NFFT, NT
TimP
It's not a question of linux vs Windows, but whether you prevent the compiler from performing any checking of arguments. In addition to type spoofing, you are mixing the idiom in use prior to 30 years ago of using array length argument (1) with the (*) form which was the standard for over 10 years from then, and remains acceptable. So, you should undertake some combination of correcting the code and turning off checking. Unless you have a reason for using on non-standard code, why not simply fix it?
geotarget
Thnaks, Tim18
how do you specify visual fortran to turn off checking when compiling, I am not good
on this visual thing and it just happen to need a quick test of old unix fortran code .
geotarget
Thnaks. I turn off the flag and Visual fortran and now is compiled and linked.
I am running it....
Thanks. Tim18
