-i flag
mrentropy1
Quickie:
I was comiling something with the -i8 flag (should force integers to be kind=8, unless specifically overriden by source e.g. integer(4) :: myint), and it wouldn't run....
System protested "Permission denied." I thought, that's weird. Anyway so then I did
$ chmod +x
and tried
and got:
cannot execute binary file
FINALLY I realized that I hadn't typed "-i8", I had typed "-i":
$ ifort -i .F90
Soon as I changed it to -i8, or just dropped it entirely, things worked fine.
So my question is, what DOES a plain -i flag do? I can't find it in man, or info, or ifort -help.
Peter
Kevin_D_Intel
Quoting - mrentropy
I think the ifort driver is behaving badly here. It seems to be ignoring the option and passing it to the linker.
In the case of compile only (-c) the option is simply ignored. In the case of compile & link, since it isn't a supported ifort option thedriverpasses it to the linker (ld) which accepts it and performs an incremental link.
$ ifort -i sample.f90
$ file a.out
a.out: ELF 64-bit LSB relocatable, AMD x86-64, version 1 (SYSV), for GNU/Linux 2.6.9, not stripped
$ ifort sample.f90
$ file a.out
a.out: ELF 64-bit LSB executable, AMD x86-64, version 1 (SYSV), for GNU/Linux 2.6.9, dynamically linked (uses shared libs), for GNU/Linux 2.6.9, not stripped
I believe ifort should issue an error (like that below) and not do what some compilers do of just ignoring the option not passing it through to the link.
$ ifort -badoption sample.f90
ifort: command line warning #10006: ignoring unknown option '-badoption'
I submitted the suggested improvementto Development.
(Internal tracking id: DPD200138822)
(Resolution Update on 12/23/2009): The -i option is one of a handful of special linker options the ifort driver accepts and passes directly to the linker. Instead of changing the behavior as suggested the option was documented under ifort -help in the Intel Fortran Compiler Professional Edition 11.1 Update 4 (11.1.064 - Linux).
Kevin_D_Intel
Quoting - mrentropy
$ file a.out
$ ifort sample.f90
$ file a.out
mrentropy1
Ahhhhh. OK. Makes sense. Thanks for figuring that out!
I should have used "file" as you did - a good 'nix command to know, for sure.....
