ifc hangs on module file
kaholcomb
I am trying to compile a well-known atmospheric model with ifc. The compiler hangs indefinitely in one of the module files, fairly early in the compilation. Has anybody seen behavior like this? So far I have been unable to winnow out a test case that I could submit through the formal support mechanism, so I am looking for clues elsewhere.
The code compiles with the PGI compiler. The developers of this model have long recommended PGI and I'm sure it has sold more than a few copies of that compiler.
I've seen problems under ifc with module files in at least one other case (the HDF library; I have a report in on that). In that case, however, at least I got an error message, albeit an apparently bogus one.
