ifort 16.0.3 bug with unlimited polymorphism
Melven_R_
Dear Intel support team
For the following code I obtain an error:
program test
  implicit none
  type SomeType
    real, pointer, contiguous :: x(:) => null()
  end type
  type(SomeType) :: t
  allocate(t%x(10))
  call doSomething(t)
  write(*,*) t%x
contains
  subroutine doSomething(myT)
    class(*), intent(in) :: myT
    select type(myT)
    type is (SomeType)
      ! not allowed!
      ! myT%x => null()
      ! allowed!
      myT%x = 7.
      ! workaround
      call assign7(myT%x)
    class default
      write(*,*) 'error'
      call exit(1)
    end select
  end subroutine
  subroutine assign7(x)
    real, intent(out) :: x(:)
    x = 7
  end subroutine
end program test
The error message shown is:
> ifort --version
ifort (IFORT) 16.0.3 20160415
> ifort test.f90
test.f90(22): error #6780: A dummy argument with the INTENT(IN) attribute shall not be defined nor become undefined.   [MYT]
      myT%x = 7.
compilation aborted for test.f90 (code 1)
As x is a pointer changing its value should be allowed though. Everything works fine, when "myT" is just declared as "type(SomeType), intent(in)" (without using "class(*)" polymorphism)!
As a workaround it is possible to call a subroutine to modify "myT%x"...
Melven
Xiaoping_D_Intel
Thanks for reporting the error. It no longer happens with 17.0 compiler which will be released very soon.
Xiaoping Duan
Intel Customer Support
Xiaoping_D_Intel
Xiaoping Duan
