ifort_intent_pointer_error.F90:[fortran]program ifort_intent_pointer_error implicit none type intp integer, pointer :: p end type integer, target :: i = 1 type(intp) :: p p%p => i print *, p%p call settwo(p) print *, p%p contains subroutine settwo(p) type(intp), intent(in) :: p p%p = 2 end subroutine end program[/fortran] gfortran accepts this:$ gfortran-4.4 -Wall -o ifort_intent_pointer_error.gfortran-4.4 ifort_intent_pointer_error.F90$ ./ifort_intent_pointer_error.gfortran-4.4 1 2however ifort complains:$ /opt/intel/bin/ifort -warn all -o ifort_intent_pointer_error.ifort-12.0.5 ifort_intent_pointer_error.F90ifort_intent_pointer_error.F90(22): error #6780: A dummy argument with the INTENT(IN) attribute shall not be defined nor become undefined.
p%p = 2--^compilation aborted for ifort_intent_pointer_error.F90 (code 1)$ /opt/intel/bin/ifort -VIntel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.0 Build 20110719Copyright (C) 1985-2011 Intel Corporation. All rights reserved.In my opinion ifort should not complain, because only the object containing the pointer may not be modified due to intent(in), but it's target may.
Thank you for the nice concise test case. It appears ifort becomes confused with naming the variable of type INTP the same as the pointer within the derived type. You may work around using either INOUT or using unique names for the variable of type INTP and the associated dummy argument, or the pointer in the derived type (and references to it).
I reported this to Development and will update this thread regarding a fix as I learn it.
(Internal tracking id: DPD200172333)
(Resolution Update on 10/14/2012): This defect is fixed in the Intel® Fortran Composer XE 2013 Initial Release (2013.0.0.079 - Linux)- Mark as New
[fortran]program ifort_intent_pointer_error implicit none type intp integer, pointer :: p end type integer, target :: i = 1 type(intp) :: t t%p => i print *, t%p call settwo(t) print *, t%p contains subroutine settwo(u) type(intp), intent(in) :: u u%p = 2 end subroutine end program[/fortran]
[fortran]program ifort_intent_pointer_errorV2 implicit none type intp integer, pointer :: p end type type intp_r1_p type(intp), dimension(:), pointer :: p end type integer, target :: i = 1 type(intp_r1_p) :: t allocate(t%p(1)) t%p(1)%p => i if (associated(t%p(1)%p)) then print *, t%p(1)%p else print *, 'not associated' end if call settwo(t) if (associated(t%p(1)%p)) then print *, t%p(1)%p else print *, 'not associated' end if print *, 'i =', i contains subroutine settwo(u) type(intp_r1_p), intent(in) :: u u%p(1)%p = 2 nullify(u%p(1)%p) end subroutine end program[/fortran]
Only the workaround of using INOUT avoids this error for this latest example and I expect perhaps for your actual program also.
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
