ifort doesn't "ASSIGN x TO y"?
jenwang
I have a program named foo.f that has many statements such as
IF ( condition >) THEN
ASSIGN 100 TO IGO2
100
GO TO IGO2
I can compile in g77 and the executable produces correct result. But when I compiled using ifort, I got the warning:
ifort -c foo.f
fortcomp: Warning: foo.f, line xx: A jump into a block from outside the block may have occurred.
GO TO IGO2
Where line xx is the statement "GO TO IGO2". The executable produces a core dump.
It seems that ifort doesn't recognize that the label IGO2 has been assigned to 100, which is a valid label. Can anyone help? Thanks!
Jeni
madhu_iitc
since u r source code is in fixed format (f77)..i guess u have to make changes to the command , which u r using to compile.
try ifort -FI filename or ifort -f77rtl filename
The compiler does support assigned goto. We would need to see a complete program to undertstand what is going wrong. The warning message suggests that you have an illegal branch back inside an IF or DO block, which can cause unpredictable results.
