29285 Discussions
ifort: error #10037: could not find 'link'
awa5114
I have recently acquired a copy of Microsoft Visual Studio 2012 and Intel Parallel Studio Visual Fortran Compiler XE 2013.
When I attempt to run a simple Fortran Program through the command prompt, I get the following error message
ifort: error #10037: Could not find 'link'
I don't really think this is an installation issue. This was how my installation procedure went:
1) Install Intel Parallel Studio XE 2013
2) Install Microsoft Visual Studio 2012
3) Uninstall Intel Parallel Studio XE 2013
4)Re-install Intel Parallel Studio XE 2013
The reason for steps 3) and 4) was that I could not see Fortran project types in Visual Studio after step 2). Steps 3) and 4) fixed this.
I would much rather fix this without having to install, uninstall or repair any of the above software. Thanks.
awa5114
@Steve
I think it worked. Here's what I did:
1) Uninstalled Visual Studio 2012
2) Uninstalled Intel Visual Fortran
3) Deleted the Microsoft Visual Studio 11.0 folder from Program Files (86)
4) Reinstalled Intel Visual Fortran.
I am now running under Microsoft Visual Studio 2010. I cannot open solutions from later versions however I can open the project of interest. Therefore I will go with this for now. Compiling a simple source file from the command prompt gave the following:
Copyright (C) 1985-2012 Intel Corporation. All rights reserved.
Intel(R) Composer XE 2013 Update 1 (package 119)
Setting environment for using Microsoft Visual Studio Shell 2010 x64 tools.
C:\Program Files (x86)\Intel\Composer XE 2013>D:
D:\>cd TEMP\FortranTest
D:\TEMP\FortranTest>ifort HELLO.f
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Inte
l(R) 64, Version 13.0.1.119 Build 20121008
Microsoft (R) Incremental Linker Version 10.00.30319.01
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:HELLO.exe
-subsystem:console
HELLO.obj
D:\TEMP\FortranTest>HELLO
 Hello World
Thanks for your help and I will update this thread if I face further problems, but I am content with this for now.
Steve_Lionel
Very good. You can now install VS2012, rerun the Intel Visual Fortran install and it will ask you if you want to add VS2012 integration. Even if that doesn't work, you can still use VS2010.
