I'm using:
$ ifort --version ifort (IFORT) 15.0.0 20140723 Copyright (C) 1985-2014 Intel Corporation. All rights reserved.
The following Fortran code:
module B_mod type :: t_B contains procedure, pass :: foo_B procedure, pass :: bar_B end type t_B interface subroutine foo_B(this) import :: t_B class(t_B) :: this end subroutine foo_B end interface interface subroutine bar_B(this) import :: t_B class(t_B) :: this end subroutine bar_B end interface end module B_mod module A_mod use B_mod, only : t_B type :: t_A type(t_B) :: b contains procedure, pass :: foo_A end type t_A interface subroutine foo_A(this) import :: t_A class(t_A) :: this end subroutine foo_A end interface end module A_mod program main use A_mod, only : t_A integer :: ierror type(t_A) :: a call a%foo_A() end program main subroutine foo_A(this) use A_mod, only : t_A class(t_A) :: this call this%b%foo_B() end subroutine foo_A subroutine foo_B(this) use B_mod, only : t_B class(t_B) :: this print *, "this is printed ..." call this%bar_B() end subroutine foo_B subroutine bar_B(this) use B_mod, only : t_B class(t_B) :: this print *, "... but this is not" end subroutine bar_B
produces the output:
this is printed ...
whereas the expected output is
this is printed ... ... but this is not
I'm declaring an explicit interface in the modules where my derived types are declared, and choosing to define the subroutines outside the module. This is closer to the C++ way of separating definition/declaration. If I remove the interface declarations and define the subroutines within the module, as in:
module B_mod type :: t_B contains procedure, pass :: foo_B procedure, pass :: bar_B end type t_B contains subroutine foo_B(this) class(t_B) :: this print *, "this is printed ..." call this%bar_B() end subroutine foo_B subroutine bar_B(this) class(t_B) :: this print *, "... but this is not" end subroutine bar_B end module B_mod module A_mod use B_mod, only : t_B type :: t_A type(t_B) :: b contains procedure, pass :: foo_A end type t_A contains subroutine foo_A(this) class(t_A) :: this call this%b%foo_B() end subroutine foo_A end module A_mod program main use A_mod, only : t_A integer :: ierror type(t_A) :: a call a%foo_A() end program main
then, the expected output is produced. Does this mean I can't separate the defintion of type-bound procedures from their declaration? As a side note, does ifort support submodules, which seem to be a way of doing this more elegantly?
FortranFan wrote:
So is it simply a separation of definition and declaration you're after? Then do look into submodules in 16.0 beta - see this link. Or is it procedure pointers you're after, as illustrated here?
I'm just interested in separating definition and declaration with this approach. It's nice that support for submodules is coming with 16.0 beta, but I mainly use ifort on supercomputers which have slightly outdated versions. To maintain portability, I need to be able to write code that compiles with older ifort versions. Most of the clusters I'm running on have ifort 14 and 15.
