29386 Discussions
ifort installed but command not found
costa__alisson
Hi there
I'm needing the intell compiler for fortran, ifort, to run a program on linux (ubuntu 16.04), the program only runs with this compiler, as there are some modules that do not perform well with gfortran.
Then I installed the program downloaded by this link (https://software.intel.com/en-us/parallel-studio-xe/choose-download) following the steps described in this installation tutorial, https://ubuntuforums.org/showthread.php?t=1082782.
I followed it to step 11 and tried to run the program and the message appeared:
ifort: Command not found.
In executing steps 12 and 13 of the tutorial I did not find the 'Compiler' directory and the subsequent ones. Is that why the ifort was not found ?
does anyone know how I can solve the ifort installation problem by following the steps in the link ?
Juergen_R_R
Valued Contributor II
Did you do a custom install? e.g. specified a special installation directory? Did you source the compilervars?
costa__alisson
no, I did not do a custom installation, I performed a default installation. What means do source the compilervars ?
I'm new in ubuntu.
Thanks in advance for you help
mecej4
Did you install the current version of the Intel Fortran compiler, or did you actually install the 8-9 year old 11.0 compiler? For each release of the compiler, Intel provides release notes that provide complete information on prerequisites, installation and utilization.
The purpose of sourcing the start-up script compilervars.sh is to make the modified environment apply to the current shell. You should become familiar with the underlying concepts if you plan to do development in Linux.
costa__alisson
I installed the current version of the Intel Fortran compiler
ali__qais
I downloaded parallel studio xe 2019 and installed intel fortran only among 14 options of other compilers, Intel Fortran compiler for Intel (R) and IA-32 component are installed successfully but when I run my program that required Intel Fortran as a compiler then I get an error.
