29277 Discussions
ifort: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ifort)
henadas
Hi, I just upgraded the intel compilers to 2024.2. I received the following error when I tried to compile a fortran code.
Could you please suggest a solution?
Devorah_H_Intel
Make sure to check the system requirements for the Linux OS part.
Do you have Linux Developer tools component installed, including gcc, g++, and related tools?
