29342 Discussions
ifort omp reduction bug in versions 16.0 and 17.0
Henneking__Stefan
I would like to report a bug in the Intel Compiler/OpenMP implementation of ifort 16.0 and 17.0. I am not sure if it has been reported before, but I could not find anything on it. The file attachment shows a little example that reproduces the bug. It is described in the README file, and implemented in the reduction.F90 file. The bug was reproduced on different systems.
-stefan
Juergen_R_R
Valued Contributor II
ifort 16 is for sure no longer under development, and I am not sure about ifort 17. I think it also out of cycle. Does the problem appear in ifort 18 and 19 as well?
Henneking__Stefan
Yes, I am aware that it may be outdated information. In fact, I noticed the bug first in Aug 2018 but had apparently reported it through the wrong channels. To answer your question: In ifort 18 the bug did not occur on the system I tested; I have not yet tried ifort 19.
Steve_Lionel
Bugs in older versions are not fixed if the bug doesn't exist in the current version. If you can't reproduce it in 19, then I recommend using 19.
Steve_Lionel
I tested this in 19 - it is correct there.
