ifx: ICE and SEGFAULT
Diehl__Martin
Dear Intel Team,
I've found a few glitches in the new ifx compiler. The code compiles fine with gfortran and ifort. I still have to see whether I can work out the MWE. The errors can be reproduced by compiling DAMASK (https://github.com/eisenforschung/damask). If someone is interested, I can share detailed build instructions.
1) Segmentation fault when finalizing a nested linked list. Error messages are
with optimization
0x000015554fca8020 in process_allocation_records_deallocate () from /home/m/intel/oneapi/compiler/2023.0.0/linux/compiler/lib/intel64_lin/libifcoremt.so.5
without optimization
0x000015554fca3fe9 in for.calc_num_elts () from /home/m/intel/oneapi/compiler/2023.0.0/linux/compiler/lib/intel64_lin/libifcoremt.so.5
traceback does not give extra information, probably because the segmentation fault happens in libifcoremt. Note: the error only occurs when enabling openMP, but the executed code is not in a parallel region.
2) Internal compiler error during the debug build. I don't think it's related to the other behavior, but it makes it impossible to compile with the whole set of debug options (-stand f18 -assume nostd_mod_proc_name -O0 -fpp -no-ftz -diag-disable 5268,7624 -warn declarations,general,usage,interfaces,ignore_loc,alignments,unused -DDEBUG -g -traceback -gen-interfaces -fp-stack-check -fp-model strict -check bounds,format,output_conversion,pointers,uninit -ftrapuv -fpe-all=0 -ftz -debug-parameters all -debug all)
#0 0x0000000001c55e52 (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x1c55e52)
#1 0x0000000001c55f80 (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x1c55f80)
#2 0x000015389d967f50 (/usr/lib/libc.so.6+0x38f50)
#3 0x000000000288f3c5 (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x288f3c5)
#4 0x0000000002c97b94 (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x2c97b94)
#5 0x0000000002d1becd (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x2d1becd)
#6 0x000000000202fe87 (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x202fe87)
#7 0x0000000001b96f59 (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x1b96f59)
#8 0x0000000001b955dd (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x1b955dd)
#9 0x0000000001b44a74 (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x1b44a74)
#10 0x0000000001d028ee (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x1d028ee)
#11 0x000015389d952790 (/usr/lib/libc.so.6+0x23790)
#12 0x000015389d95284a __libc_start_main (/usr/lib/libc.so.6+0x2384a)
#13 0x0000000001982da9 (/home/m/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom+0x1982da9)
/tmp/ifx0762407692YaNe58/ifxWdR7CS.i90: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for /home/m/DAMASK/src/math.f90 (code 3)
make[3]: *** [src/CMakeFiles/DAMASK_grid.dir/build.make:388: src/CMakeFiles/DAMASK_grid.dir/math.f90.o] Error 3
make[2]: *** [CMakeFiles/Makefile2:98: src/CMakeFiles/DAMASK_grid.dir/all] Error 2
make[1]: *** [Makefile:136: all] Error 2
make[1]: Leaving directory '/home/m/DAMASK/build/grid'
make: *** [Makefile:13: grid] Error 2
Ron_Green
The option -ftrapuv is the source of the ICE.  I'm not sure if we have fully implemented the FP exception handling in IFX.  I will check into this. For sure it gives me something to work with.
Ron_Green
Let's start with the ICE first. I've cloned the repo. Send build instructions to get the ICE.
Diehl__Martin
thanks.
the following bash script should work:
source ~/intel/oneapi/setvars.sh
wget https://ftp.mcs.anl.gov/pub/petsc/release-snapshots/petsc-3.18.5.tar.gz
tar -xf petsc-3.18.5.tar.gz
cd petsc-3.18.5
export PETSC_DIR=$PWD
export PETSC_ARCH=oneapi
sed -i "1719s/if not os.path.isfile(os.path.join(self.packageDir,'configure')):/if True:/g" config/BuildSystem/config/package.py
./configure \
          --with-fc='mpiifort -fc=ifx' \
          --with-cc='mpiicc -cc=icx' \
          --with-cxx='mpiicpc -cxx=icpx' \
          --download-fftw --download-hdf5 --download-hdf5-fortran-bindings=1 --download-zlib
make all
cd ..
git clone git@github.com:eisenforschung/DAMASK.git
cd DAMASK
make grid BUILD_TYPE=DEBUG
Ron_Green
I have it building and ICE'ing on math.f90.   It took a while, a lot of manual intervention.  Our intranet does not allow ftp, nor wget to sites with 'ftp' in the name.
Also, I started on a server with an older autoconf and that was tripping up a lot of the petsc build.
I'll get working on the ICE.
Ron_Green
Steve_Lionel
-ftrapuv never did anything useful in ifort - I lobbied (unsuccessfully) to get it deprecated.
Diehl__Martin
with a working PETSc installation it is also trivial to trigger the runtime error: Build DAMASK in release mode and run the example. That means, the last lines are
make clean grid
cd examples/grid
../../bin/DAMASK_grid -l tensionX.yaml -g 20grains16x16x16.vti
Ron_Green
@Diehl__Martin  The bug ID is CMPLRLLVM-46264.
The -fptrapuv turned out to be interesting.  one of the things this options does is to initial new memory to signaling NaNs.
You will find the same Internal Compiler Error (ICE) if you use
   -init=snan
this in conjunction with a named block seems to be the trigger.  I was able to reduce this down to the following simple reproducer:
subroutine selfTest()
  normal_distribution: block
    real(4), dimension(:), allocatable :: r
    real(4) :: mu, sigma
    if (.true.) &
      error stop 'math_normal(sigma)'
  end block normal_distribution
end subroutine selfTest
No PetSCI or MPI or module or .... just
ifx -c -O0 -init=snan math.f90
  We missed the upcoming Update 1 code freeze, so we're looking at Update 2 for a fix roughly early to mid-summer.   If you avoid -fptrapuv or -init=snan (or any other value) you can avoid this error.
So what do I need to look at next for DAMASK if we build without these options?
Steve_Lionel
Interesting. When I was at Intel, I complained that -ftrapuv didn't initialize to a NaN, but to some weird pattern (I think it was hex 80808080). The documentation was changed to say, "Initializes stack local variables to an unusual value to aid error detection.", which it still says. But in current ifort it really does initialize to a signaling NaN, 7FBADDAD(!).
The documentation does say that this option is ifort-only. ifx accepts it without complaint but ignores it.
Diehl__Martin
thanks!
From my side, there are no further issues related to DAMASK.
Ron_Green
-ftrapuv is implemented in IFX.
The Dev Guide documentation is out of date.   I'll get that fixed
We implemented -ftrapuv recently.  But your point about use of ftrapuv still holds.  this is a somewhat dangerous option.  Floating point speculation can cause FP exceptions, and appear in places in your code that make no sense.  Be sure to read THIS CAUTIONARY WRITEUP if you are considering -ftrapuv.  In short, only use O0 if you use this option, don't override O0 with O1, O2, O3.
Here is a Linux example of use of ftrapuv with ifx 2023.0.0
module calcu
contains
 subroutine calc(ans)
  implicit none
   real :: ans
   real :: no_value
   ans = ans / no_value
 end subroutine calc
end module calcu
program trapme
use calcu
real :: a=42.0
call calc(a)
write(*,*) "a is ", a
end program trapme
and the runtime result
ifx -V -ftrapuv -g -traceback -o ftrapuv ftrapuv.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2023.0.0 Build 20221201
Copyright (C) 1985-2022 Intel Corporation. All rights reserved.
ifx: remark #10440: Note that use of a debug option without any optimization-level option will turnoff most compiler optimizations similar to use of '-O0'
 Intel(R) Fortran 23.0-1198
GNU ld version 2.37-37.fc36
$ ./ftrapuv
forrtl: error (182): floating invalid - possible uninitialized real/complex variable.
Image              PC                Routine            Line        Source
libc.so.6          00007F1F2183EA30  Unknown               Unknown  Unknown
ftrapuv            00000000004051E2  calc                       10  ftrapuv.f90
ftrapuv            0000000000405216  trapme                     19  ftrapuv.f90
ftrapuv            000000000040519D  Unknown               Unknown  Unknown
libc.so.6          00007F1F21829510  Unknown               Unknown  Unknown
libc.so.6          00007F1F218295C9  __libc_start_main     Unknown  Unknown
ftrapuv            00000000004050B5  Unknown               Unknown  Unknown
Aborted (core dumped)
Steve_Lionel
I tried -ftrapuv in ifx and the real variable got initialized to zero, which is why I thought it was ignored.
Ron_Green
did you test this on Windows?  I haven't tried Windows and wonder if it's different or broken on Windows.
I put in a Documentation bug for the ftrapuv option.
Steve_Lionel
Yes, Windows. But I modified the program a bit and now I get the same SNaN. Hmm. I am also seeing:
D:\Projects>ifx /Qtrapuv t.f90
ifx: remark #10440: Note that use of a debug option without any optimization-level option will turnoff most compiler optimizations similar to use of '/Od'
Ron_Green
<sigh> FTRAPUV turns off the optimization and turns on debug.  As you know, by default we set O2.  FTRAPUV resets to O0. A debug option without any explicit -O option causes this warning.    Since we used FTRAPUV, we implicitly get debug but we do not have an explicit -O option.
I strongly protested when they did this.  Some noisy Intel field engineer complained that he didn't know -g or getting debug would turn off optimization unless he explicitly added a -O[1-3] option.  IMHO compiler options 101 that this chap apparently never learned.  And a few of his fellow field engineer types also claimed ignorance.  Thus some management types demanded that we warn people that -g or windows equivalents turn off optimization and SHOULD be followed by a -O option.
Steve_Lionel
And yet ifort doesn't do this....  I did not see the message when I tried ifx earlier - strange.
I have always found -ftrapuv to be a mysterious option - it seems to have additional effects beyond initialization. Or is it now just an alias of -init=snan, which doesn't give this warning in ifx?
andreasskeidsvoll
I would just want to chime in and say that I've encountered segfaults related to finalization at several places in a development version of the eT program compiled with ifx 2023.1 and -qopenmp, breaking almost all of our end-to-end tests. From what I can see from gdb, the segfault always seems to occur in for.calc_num_elts, called by for_finalize, and the issue disappears when I compile without the -qopenmp flag. I have not been able to create a MWE yet, but I could prepare a branch of the eT program if anyone wants to reproduce the segfaults.
Ron_Green
this bug is fixed in the 2024.0 release.
gumle_maasegg
the attached code does not compile. How can I know more about what goes wrong ? At the moment I do not have access to the 2024 version.
saue@lcpq-ampere:~/Dirac/src/amfi> ifx --version
ifx (IFX) 2023.1.0 20230320
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
saue@lcpq-ampere:~/Dirac/src/amfi> ifx amfi.f
#0 0x0000000001f63112
#1 0x0000000001fc5727
#2 0x0000000001fc5850
#3 0x00007f153d6dadc0
#4 0x0000000003a3a098
#5 0x0000000003a39e9c
#6 0x0000000002a87afb
#7 0x0000000002a87d0e
#8 0x0000000002a87999
#9 0x0000000002a841c3
#10 0x0000000002a83e51
#11 0x0000000002a86679
#12 0x0000000003a3d004
#13 0x0000000003a3c794
#14 0x0000000003a36310
#15 0x0000000003a36c4f
#16 0x0000000003a35c4e
#17 0x0000000003a35457
#18 0x0000000002e90f5d
#19 0x00000000022ebeec
#20 0x0000000002e84fbd
#21 0x00000000022f30b7
#22 0x0000000002e8519d
#23 0x00000000022eaa8a
#24 0x0000000001f08104
#25 0x0000000001f06b83
#26 0x0000000001eb5859
#27 0x00000000020797c5
#28 0x00007f153d6c524d __libc_start_main + 239
#29 0x0000000001cf1729
amfi.f: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for amfi.f (code 3)
Ron_Green
Perhaps I should have been more clear - this bug is fixed FIRST in version 2024.0.  All older versions have this bug.  You need to upgrade to 2024.0 (latest)
Steve_Lionel
It compiles OK for me using version 2024.0.2. Internal compiler errors are always compiler bugs, and it seems that whatever this one was, it got fixed. Sometimes one can identify a compiler option that triggers the error, but you used none.
