29300 Discussions
fatal error LNK1104: cannot open file 'mkl_intel_lp64.lib
mmavro
I am trying to compile a program using Microsoft visual studio and intel fortran compiler and I have the following issue:
'LINK : fatal error LNK1104: cannot open file 'mkl_intel_lp64.lib'
Can you please help me with that?
mmavro
Thank you both for your replies. The issue was that the system couldn't find the mkl library because it was simple not installed.
It is the first time I am using oneAPI and I installed directly the HPC kit without installing the base kit (i thought the base kit was included in the HPC kit).
Arjen_Markus
Have you added that library with an appropriate path to the list of additional dependencies? My Intel oneAPI installation has it in: c:\Program Files (x86)\Intel\oneAPI\mkl\2021.4.0\lib\intel64\
Chandubhusan
Can you please provide the steps of how to do it?
Barbara_P_Intel
@Chandubhusan, I suggest you post your question with the error message and a way to reproduce your issue on the MKL Forum. Here's the link.
mecej4
There is another circumstance in which the reported error message may be expected. If a source file was compiled for 64-bit and the project/compiler had MKL usage selected, the OBJ file may contain a reference to mkl_intel_lp64.lib.
If a subsequent 32-bit build attempts to use that 64-bit OBJ file, the linker will note the reference to the library in the OBJ file and issue the error message. A more helpful error message that the linker could have issued would be something similar to "attempted linking of 64-bit OBJ file in 32-bit build".
mmavro
