hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
28991 Discussions
implicit none(type, external) discussion
andrew_4619
Prompted by another thread I installed XE2020 update 1 (from XE2019 U4). I seem very disappointed by the new attributes on IMPLICIT NONE.  I was expecting a compile error because of no explicit interface for subroutine fred but that is not the case, I only get the linker error at the end of the build. So I can't really see any real benefit for this feature other than if you declare a function but don't give it the EXTERNAL attribute which in itself isn't very useful. Am I missing something?
module fred
    implicit none
    contains
    subroutine blogs(istat)
        integer, intent(out) :: istat
        istat = 42
    end subroutine blogs
end module fred
program main
    !use fred, only: blogs
    integer         :: istat
    call blogs( istat )
    print *, istat
end
Steve_Lionel
I don't think you're missing anything. It's a bug - please report it. At first I wondered if there was some symbol table side-effects of having BLOGS declared in the module, even though the USE was commented out. The compiler has had issues before with symbol table entries not being fully cleaned out. But some testing showed that was not the case here.
The issue seems to be if you use (EXTERNAL, TYPE) or (TYPE, EXTERNAL). When both keywords appear, EXTERNAL is ignored. If you just have (EXTERNAL), it works.
t.f90(14): error #8889: Explicit declaration of the EXTERNAL attribute is required.   [BLOGS]
    call blogs( istat )
andrew_4619
OK thanks that is useful then as the type attribute is default anyway. I will file a ticket.
Steve_Lionel
IMPLICIT NONE (TYPE) is not the default (unless you compile with /warn:declarations.) You can't repeat IMPLICIT NONE, either.
andrew_4619
By default I meant that IMPLICIT NONE (TYPE) statement is the same as an IMPLICIT NONE statement.
andrew_4619
FYI "Hello, An update was made to service request on July 17, 2020: I have reproduced this bug and escalated to be corrected (CMPLRIL0-33125). Thank you for reporting it."
andrew_4619
This is fixed in the "latest compiler" I am informed, not tested as yet.
