installing MKL C++ components seems to break VS 2015 integration
Johannes_Rieke
New Contributor III
I installed PSXE 2017 update 2 today and in the customized installation section I added the C++ components of MKL (IA32, x64) for different reasons (Composer Edition for Fortran Windows --> no Intel C++ compilers). I experienced, that these MKL C++ components seems to break the Fortran integration for VS2015 (blank screen in editor, cannot compile).
After removing these MKL C++ components the VS 2015 Fortran integration works fine again. Maybe it's related to the issue I reported here https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/635254 Maybe it's just something seen on my computer...
Microsoft Visual Studio Professional 2015
Version 14.0.25431.01 Update 3
Microsoft .NET Framework
Version 4.6.01055
Intel® Parallel Studio XE 2017 Update 2 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2015, Version 17.0.0041.14, Copyright © 2002-2017 Intel Corporation. All rights reserved.
* Other names and brands may be claimed as the property of others.
Steve_Lionel
This error is caused by a corrupted Visual Studio cache.
Close all Visual Studio tasks that are running, and delete all files in the folders ComponentModelCache and MEFCacheBackup
these folders are located in:
\Users\YOUR_USER_PATH\AppData\Local\Microsoft\VisualStudio\14.0
Works for me!
Microsoft has acknowledged this as a VS bug to be fixed in an update.
Steve_Lionel
I can confirm this in part. When I install Update 2, I can still compile and build, but can't edit - opening a Fortran source shows a blank screen. However, I don't have MKL installed at all (I deselected it on initial install and I confirmed it is not there.)
Kevin_D_Intel
Thank you both for reporting this issue. I escalated this to the integration developers.
(Internal tracking id: DPD200418211)
Kevin_D_Intel
Our Developers requested some additional details to from each to help with reproducing this:
  1. OS Version?
  2. Which VSs are installed?   (VS 2015 only or any other as well?)
  3. Which other Intel compiler-related products were on the system, and to which VS were they integrated before installing PSXE 2017 Update 2 Composer Edition for Fortran for Windows?
  4. Was this a default PS XE 2017 Update 2 installation + MKL C++ component, or some other custom configuration?  (From my read of each of your details I think this is a “yes” for Johannes and an a “no” for Steve, where Steve you may have deselected MKL from the default installation.)
  5. Was integration to all VS selected during installation, or only to VS 2015?
Steve_Lionel
Windows 10 x64
VS2015 only
PSXE 2017 RTM and Update 1
I did not change the defaults for this install - it saw I had deselected MKL from an earlier install
This is not a question that gets asked in a normal install - only if you customize.
I am going to uninstall all PSXE and reinstall and see what happens.
I'll also send Kevin the install logs.
Steve_Lionel
Uninstall all and reinstall from scratch did not help. Same symptom.
Steve_Lionel
Reproduced it on a second computer. This one also had PSXE 2016 installed. I uninstalled everything and then installed 2017U2 with MKL and Parallel Debug extension deselected. Can't edit Fortran sources. Interestingly, when I went to open a different Fortran project, VS2015 crashed.
On second computer, I did a Modify and added back in MKL and the MIC debugger extension. Now I could edit. Removed debugger extension, still could edit. Removed MKL, still could edit!
Johannes_Rieke
New Contributor III
On my side I have
  • Win 7 Enterprise x64,
  • VS 2010 SP1
  • VS 2015 U3
  • PSXE 2016 U3 with MKL
  • PSXE 2017, U1, U2 (all with default, besides U2)
  • VS Integration was installed with every new version, since PSXE 2017 only for VS 2015 (Professional)
As Steve said, a 'Modify' and removing MKL C++ did the trick for me too to get things running again. It might be, that I could have been able to build, although the screen was blank.
Steve_Lionel
Works for me!
