29276 Discussions
intel fortran with the wrong glibc path
c_inostroza
i have this problem when i try to compile
ifort simpson.f90 -o tt
ld: /usr/lib/gcc-lib/i486-linux/3.3.5/crtbegin.o: No such file: No such file or directory
anyone knows how to work this arround?
Message Edited by c.inostroza@gmail.com on 11-04-2005 03:00 PM
TimP
You must have a working gcc installation. If you have updated your gcc installation, and are not using ifort 9.0, you should re-install ifort, or modify the configuration files to match your current setup. If you are accessing an ifort installation across a network which was installed with a different gcc setup than exists on your computer, you will not be able to run versions prior to 9.0.
c_inostroza
mmm, i have updated my gcc, but ive reinstalled ifort, and im using ifort 9.0, wich are the configuration files i have to modify?, thanks for your help
