iostat error 104
tropfen
using the following source i get the iostat error 104
open(unit=10,file=file2,access="sequential", status="old",action = "read", position = "rewind", iostat=iFehlerio)
The file is present and not empty. A couple of lines before in the program i was able to open and read the file. There is no documentation in the fortran help file.
What does the error mean?
Thanks in advance
Frank
DavidWhite
Valued Contributor II
tropfen
if i try the given link i get the following error message:
Page Not Found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable. Please check the address bar to make sure the link is typed correctly, use the links above in the menu to locate the information you want, or search the site for another destination.
If you believe you have reached this page in error, please contact ISN Customer Support with the URL you are trying to reach.
Frank
DavidWhite
If you search the forum for 104 you should be able to find the thread - that's how I found it.
David
The URL dhould be http://software.intel.com/en-us/forums/showthread.php?t=70068&o=a&s=lr The forum is messing it up.
Error 104 indicates that one of the keyword values passed to the OPEN routine has an invalid value. It might be that some code elsewhere in your program has corrupted memory. Can you come up with a minimal test case that causes this error to occur?
tropfen
Hello Steve,
based on your hints i have added 'iomsg=c_iomsg' to the open statement. Then i was reciving the message:
incorrect POSITION=specifer value for connected file
The unit number i am using quite often in the program. All units will be closed after using. Changing the dummy number 10 to 1011 solved the problem.
It locks like the program has problems the close the file correctly.
The problem only occurs on the following configuration:
- Win7 64bit German
No Problems so far on Win XP 32bit and Win Server 2008 64bit.
Frank
I see. What is happening is that you are doing an OPEN on a unit that is already open. The Fortran language restricts which OPEN keywords you may use in this case. You should make sure that the unit is CLOSEd before opening it again.
TimP
From time to time, we have observed a latency issue, where Windows doesn't complete all the actions initiated by CLOSE quick enough to allow a subsequent OPEN.
Tim,
That's true, but not what is going on here. In this case, Fortran has not seen a CLOSE on the unit.
