- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I have successfully used the keybd_event function in a program that I haven't re-compiled since 2001 (compiler version unknown). Now, I am re-compiling/linking that program and get the following error even though the source code hasn't changed in ages. Thanks for any help
Microsoft Incremental Linker Version 6.00.8447
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
/subsystem:windows
/entry:WinMainCRTStartup
/ignore:505
/debugtype:cv
/debug:minimal
/pdb:none
C:DOCUME~1ADMINI~1.000LOCALS~1Tempobj70.tmp
PVIO.OBJ
GRAPHQW.OBJ
dformt.lib
libcmt.lib
dfqw_mdi.lib
dfqwin.lib
user32.lib
gdi32.lib
comdlg32.lib
dfport.lib
kernel32.lib
/out:SCANMF8.exe
/incremental:no
GRAPHQW.OBJ : error LNK2001: unresolved external symbol _KEYBD_EVENT@16
SCANMF8.exe : fatal error LNK1120: 1 unresolved externals
NMAKE : fatal error U1077: 'C:BATDFVARS.BAT' : return code '0x460'
Stop.
/subsystem:windows
/ignore:505
/debugtype:cv
/debug:minimal
/pdb:none
PVIO.OBJ
GRAPHQW.OBJ
dformt.lib
libcmt.lib
dfqw_mdi.lib
dfqwin.lib
user32.lib
gdi32.lib
comdlg32.lib
dfport.lib
kernel32.lib
/out:SCANMF8.exe
/incremental:no
Stop.
- Marcas:
- Intel® Fortran Compiler
Link copiado
3 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hah, it seems it's a DFWIN bug -- there is no INTERFACE to keybd_event in user32.f90 -- although it was there even in CVF5.0. (Superficially, it looks as if someone was manually fixing the result of automatic translation from winuser.h (there's a MSFWIN$ added at mouse_event) and screwed it up...).
As a workaround, you should put the INTERFACE block in the routine(s) that calls keybd_event:
Jugoslav
interface subroutine keybd_event (bVk ,bScan ,dwFlags ,dwExtraInfo ) !DEC$ IF DEFINED(_X86_) !DEC$ ATTRIBUTES STDCALL, ALIAS : '_keybd_event@16' :: keybd_event !DEC$ ELSE !DEC$ ATTRIBUTES STDCALL, ALIAS : 'keybd_event' :: keybd_event !DEC$ ENDIF BYTE bVk BYTE bScan integer dwFlags integer dwExtraInfo end subroutine keybd_event end interface
Jugoslav
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I was trying to use mouse_event in a win32 app as I was converting my quickwin ones. Tried to apply this example into mouse_event but I am not succesful.
Basically, in quick win I use
and want the equivalent of that in Win32
I tried
The error I get is
Error: This PARAMETER constant name is invalid in this context. [MOUSE_EVENT]
Can you please help.
bret=waitonmouseevent(MOUSE$RBUTTONDOWN,keystate,ixpos,iypos) if (keystate==MOUSE$LBUTTONDOWN) then .... end if
I tried
bret= mouse_event(dwFlags,dx,dy,dwData,dwExtraInfo) if (dwFlags == MOUSEEVENTF_RIGHTDOWN) then iret= Messagebox(ghwndmain,'PROCEED ?','Please Click Left Mouse Button'C,MB_ICONEXCLAMATION .OR. MB_YESNOCANCEL) IF(IRET == IDYES) then logi=.FALSE. end if
The error I get is
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
MOUSE_EVENT is a PARAMETER in DFWINTY.f90, and the function is renamed to msfwin$mouse_event (because Fortran is not case-sensitive). However, it will not solve your problem, as it does something quite different than WaitOnMouseEvent -- it just "simulates" a mouse click. There's no Win32 equivalent of WaitOnMouseEvent.
Jugoslav
Jugoslav
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
