libiomp problem
roddur
i have installed ifort11.074 in fedora10.while i compile my threaded job , it shows error
error while loading shared libraries: libiomp5.so: cannot open shared object file: No such file or directory
while this library is present in the same file as .a version. a obvious workaround is compile the job statically. but my worry is why it cannot access the libiomp.so while it can access libiomp.a residing in the same dir.?
Rafael_Barreto
I don't know if it will solve your problem.
But make sure the library directory is in the ld path.
In Slackware, I put the path in /etc/ld.so.conf
pc:~$ cat /etc/ld.so.conf
/usr/local/ga-4-0-8/lib/LINUX64
/usr/local/intel/cce/10.1.012/lib
/usr/local/intel/fce/10.1.012/lib
/usr/local/intel/mkl/10.0.1.014/lib/em64t
/usr/local/lib
/usr/i486-slackware-linux/lib
After this you must run, as root, ldconfig command.
I am not sure, but there are another ways, such as put the library path in LD_LIBRARY_PATH, and export it.
TimP
Quoting - Rafael Barreto
As Rafael indicates, the expectation is that you set LD_LIBRARY_PATH, as sourcing one of the ifortvars scripts would do.
roddur
Quoting - tim18
how idiot i am...i did had LD_LIB_PATH.....but fotgot that i had to update that as well(as i update from 10.1 to 11.0) ..... anyway, thanks for your help.
jimdempseyatthecove
Quoting - roddur
Quoting - tim18
Welcome to the club. We've all been there - don't feel so bad :~)
Jim Dempsey
