When using '-stand 03' option to ifort I'm getting warnings about the line length, even though they are below the 132 allowed by the standard. In all cases it involves a variable name being split across 2 lines. Here are the 2 lines of code in question:
[fortran] res(21)=5.d-1*t134375*(1.5d0*t134375*t134382+5.d-1*t134375*(-(t134374*t134375*t134380)+5.d-1*t134375*(t134444+5.d-1*t134374*t13& &4375*t134445)))[/fortran] and here is the resulting warning when compiling with '-stand 03':
[plain]basis_shell_pg_kpoint.F90(189): warning #5268: Extension to standard: The text exceeds right hand column allowed on the line. res(21)=5.d-1*t134375*(1.5d0*t134375*t134382+5.d-1*t134375*(-(t134374*t134375*t134380)+5.d-1*t134375*(t134444+5.d-1*t134374*t134375& ------------------------------------------------------------------------------------------------------------------------------------^[/plain]
So it appears the compiler has moved the line ending onto the next line and is counting the line plus the remainder of the variable name on the next line when calculating the line length. Is this correct? Surely the line length check should not 'extend' onto the next line?
This is seen with:
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.2.137 Build 20110112 Copyright (C) 1985-2011 Intel Corporation. All rights reserved
Any ideas what the problem is?
Many thanks
Andy
[fortran]res(21)=5.d-1*t134375*(1.5d0*t134375*t134382+5.d-1*t134375*(-(t134374*t134375*t134380)+5.d-1*t134375*(t134444+5.d-1*t134374*t134375& &*t134445)))[/fortran]
When the variable name is rejoined and the original source line begins in column 2 or greater, the line then exceeds the 132 character length and that triggers the warning. The error does not occur when the original line begins in column 1.
The warning is also avoidable using the .f90 extension or not splitting the variable name across two lines as so:
[fortran]res(21)=5.d-1*t134375*(1.5d0*t134375*t134382+5.d-1*t134375*(-(t134374*t134375*t134380)+5.d-1*t134375*(t134444+5.d-1*t134374*& &t134375*t134445)))[/fortran]
Unclear whether this would be considered a defect or not or whether this may have been reported before. I will report this to the Developers and note the internal tracking id below.
(Internal tracking id: DPD200172620)
So, the preprocessor rewrites lines 132 characters in length but without regard to leading white space, thus the line exceeds the Standard and triggers the warning. That is a defect in the preprocessing in my view.
Sure, we have some '#ifdef' etc. in our files so we use .F90 suffix to envoke the preprocessor.
Thanks for the explanation, I now understand what's happening. I'm not sure the preprocessor should get involved in this case; it's plain Fortran which should be invariant under the action of the preprocessor.
At present the behaviour of ifort differs from all other compilers, eg.:
ifort -E test.F90 > ifort.F90
does not agreee with:
gfortran -E test.F90 > gfortran.F90
openf90 -E test.F90 > openf90.F90
cp test.F90 sunf90.F90; sunf90 -F sunf90.F90
which all do not rejoin the line.
If these become a major nuisancethe best work around is to silence them by adding the option: -diag-disable 5268
Development found the root cause. A fix will be available in a future release wherepreprocessig will no longer join two parts of a token separated by the & unless it appears within a macro definition where joining is required.
I will update this thread when a fix is available.
