lnk2019 error from Main
drew14385
I am fairly new to Fortran and am in the middle of writing a code. I have a main file and I use the 'Use' statement to reference about 12 different modules that contain subroutines. Each module and subroutine compile fine seperately. When I use IVF to compile the main file it goes through all of the modules and then says "Linking...". I then get errors for nearly every variable I declared. Examples are:
main.obj : error LNK2019: unresolved external symbol _QRR referenced in function _MAIN__
main.obj : error LNK2019: unresolved external symbol _QET referenced in function _MAIN__
main.obj : error LNK2019: unresolved external symbol _QETT referenced in function _MAIN__
main.obj : error LNK2019: unresolved external symbol _QINFF referenced in function _MAIN__
I have tried research this problem for quite some time and can not find the solution, although I have a feeling it may be a simple fix. I have tried adding each file to the include directory, but still get the errors. Does any have an idea what I am doing wrong? Thanks in advance!
mecej4
When you compile source files (.f90) containing modules, corresponding module (.mod) and object (.obj) files are produced. During compilation of other sources that USE the modules requires that the .mod files be available. In the final link step (in your case, following the compilation of the main program) all the .obj files containing the codes for the modules need to be included.
If, for instance, you have .obj files called QRR.obj, QET.obj, QETT.obj and QINFF.obj, the final command would be
ifort main.f90 QRR.obj QET.obj QETT.obj QINFF.obj
IanH
If the module obj's were missing in the link stage, the symbols that were unresolved would look a bit like _ModuleName_mp_VariableName. What the OP is seeing suggests that the compiler doesn't think that his variables are actually module variables. Maybe substitute "procedure" for "variable": convincing the compiler that a non-module-variable is an external of some sort is beyond me.
To the OP - are the unresolved symbols similar to your subroutine names or variable names? You say "each module and subroutine" - the subroutines would normally be part of the module, what exactly do you mean? If you are using modules it is unlikely that you want the files to be in the "include directory" (assuming you are talking about the folder in the VS project tree?). If the compiler can't find the modules while compiling your main program it will complain directly about that - in that case you might need to specify the directory that contains the module files to the compiler, but that means that you've got more than one project or similar on the go.
I suggest that you post the top bit of your PROGRAM (where the use statements are down to an example subroutine call or variable reference) and a part of one of your modules. Something ain't right...
drew14385
To address your points:
- The unresolved symbols are variable names.
- Each module compiles correctly and the subroutines are included in the modules.
"If the compiler can't find the modules while compiling your main program it will complain directly about that - in that case you might need to specify the directory that contains the module files to the compiler, but that means that you've got more than one project or similar on the go."
This sentence is exactly what happens when I compile the main program...maybe I have a problem with my hierarchy.
Here is the top of the main program:
Program WETSAND
Use XRAINPETINF
Use XPETX
Use XINFILTRATION
Use XINPUTSX
Use XINTERACTION
Use XUPLANDIMP
Use XQUALITYDATA
Use XAXX
Use XNITROGEN
Use XPHOSPHORUS
Use XWETLANDIMP
Use XSTREAMIMP
Use XAXXX
Use XHEADARDIS
Use XSTORAGE
Use XLINTERP
Use XLATERALX
IMPLICIT NONE
!------------------------Inputs------------------------------------!
Common/name/dt,nt
Real::Li,md,ri,T,DH,qet,qett,qrr,qinff,P,F,delt,gwl,y_ubc, Q_ubc, ql, h, qr, qinf, qu, yu, uu, q, y, u, qall, yimpw, qimpw, uimpw, CLTP, CLON, CLAN, CLNN, CLTN, CTP_ubc, CON_ubc, CAN_ubc, CNN_ubc, CTN_ubc,yimpu, Ax, qdrchp, CONnn, CANnn, CNNnn, CTNnn, uimpu, CTPnn, qw, yw, uw, qdrch, kz, IMC, kx, S, tn, CgwTP, CgwON, CgwAN, CgwNN, CgwTN, JUAN, JUNN, JRON, ddx, KTP, KON, KAN, KNN, KTN, psi, CTP_ic, CON_ic, CAN_ic, CNN_ic, CTN_ic, LW,So,KK,W,m, delta, y_ic, u_ic, y_lbc, Q_ic, mn, z, glwet,EP, Qs, us, ys, qstream, ustream, ystream, head, area, Qdam, Qlake, ulake, ylake, Qinflow, ul, yl, qdrchpl
Integer::a, tc, nt, nnt, nn, dx,i, j, dt, Lt, wq
Call RAINPETINF(a,dt,Lt,wq,ri(3320),T(12),DH(12),kz,S,EP,IMC,kx,qrr(3320))
tc=1/dt !time constant
nt=tc*Lt+1 !number of time steps
Call PETX(T(12),DH(12),qet(12),qett(12)) !evapotranspiration
Call INFILTRATION(kz,S,EP,IMC,qrr(3320),qinff(1,nt),P(1,nt),F(1,nt)) !infiltration [qinff,P,F]
Here is the XRAINPETINF module, which contains the called subroutine 'rainpetinf':
MODULE XRAINPETINF
IMPLICIT NONE
CONTAINS
subroutine RAINPETINF(a,dt,Lt,wq,ri,xT,xDH,kz,S,EP,IMC,kx,qrr)
!a
!GENERAL INFORMATION:
Real::qrr(3320),ri(36),xT(12), xDH(12),KZ,KX,S,EP,IMC
Integer::a, dt,i, j, valri, Lt, wq
dt=1 !time step (hr)
Lt=3319 !365*24 - total time length of the simulation (hr)
wq=1 !if wq=1 then water quality calculated, if wq=0 then water qulaity is not calculated.
!RAINFALL DATA
ri=(/ 0.0, 0.0005, 0.0005, 0.0002, 0.0002, 0.0003, 0.0003, 0.0002, 0.0002, 0.0005, 0.0005, 0.0001, 0.0001, 0.0002, 0.0002, 0.0, 0.0, 0.0001, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 , 0.0, 0.0 ,0.0, 0.0 ,0.0, 0.0, 0.0 ,0.0 ,0.0 ,0.0 /); !september 26
valri = size(ri)
Do i = 1,valri
qrr(i)=ri(i)
Do j= (valri+1),3320
qrr(j) = 0
End do
END DO
!EVAPOTRANSPIRATION DATA
xT=(/ 4.4, 6.1, 10, 16.7, 18.3, 24.4, 26.1, 25, 21.7, 15.6 ,7.8, 3.9 /); !historical average monthly temperature (in celcius) (for Durham-2002)
xDH=(/ 0.87, 0.85, 1.03, 1.09, 1.21, 1.21, 1.23, 1.16, 1.03, 0.97, 0.86, 0.85 /); !mean possible hours in units of 30 days of 12 hours each (data for N35-lat)
!INFILTRATION DATA
!Choose silt loam type of soil:
kz=0.5*6.5*10**(-3) !6.5*10^(-3) - Hydraulic conductivity [m/hr] Ref:Rawls, Brakensiek, Miller (1983) !vertical hydraulic conductivity
kx=0.5*6.5*10**(-3)
S=166.8*10**(-3) !suction head
EP=0.486 !effective porosity
IMC=0.45 !initial moisture content
END SUBROUTINE RAINPETINF
END MODULE XRAINPETINF
Thank you for your help!
Jugoslav_Dujic
Valued Contributor II
Here lies the immediate culprit:
Real:: ...qrr...
You declared that QRR is REAL, but not that it is an array. Without the dimension, compiler thinks that QRR(3320) is a function call, and generates a call to it (_QRR) to be later resolved by linker. However, linker cannot find it.
However, it is not clear to me what was the intent. Did you mean:
[bash]REAL:: QRR(3320) !declares the dimension in the main program
CALL RainPetInf(...QRR)
MODULE XRAINPETINF
CONTAINS
SUBROUTINE RainPetInf(...QRR)
Real::qrr(3320)[/bash]
mecej4
Ah, now that you have shown us some code, a better diagnosis can be made.
QRR, QET, QETT, QINFF are declared as REAL scalars in the main program, although the apparent intention is for them to be arrays. In the absence of an array declaration, the compiler sees a reference such as qrr(3320) in the call to RAINPETINF as a function reference, with integer argument 3320. At link time, the referenced function is not found.
The usage in your program of arrays such as QRR -- with the upper bound as subscript in the call, and a declaration with that upper bound in the subroutine or function called -- is a sign of misunderstanding as to how arrays are declared in the caller, passed to a subprogram as an argument, and declared as a dummy argument in the subprogram. Please consult the Fortran Ref. Manual.
Perhaps, what you need is something such as
(in the main program)
REAL :: QRR(3320)
Call RAINPETINF(a,dt,Lt,wq,ri,T,DH,kz,S,EP,IMC,kx,qrr)
If you call the subroutine with the last actual argument as QRR(3320), what you do is to ask the 3320-th element of the array to be passed (usually by reference), rather than the array with size 3320.
