logical and behaviour
David_Mccabe
Hi.
The output from the following program is:
test1 invoked
test2 invoked
[fortran]
program IfAnd
    if (test1().and.test2()) then
        ! do nothing
    endif
    write(*,"(A)") "hit return..."
    read(*,*)
contains
    function test1()
    logical test1
        test1 = .false.
        write(*,"(A)") "test1 invoked"
    end function test1
    function test2()
    logical test2
        test2 = .false.
        write(*,"(A)") "test2 invoked"
    end function test2
end program IfAnd
[/fortran]
I was expecting only one procedure to be evaluated as the second evaluation is unnessesary.
Q. Is there some compiler switch to change this behaviour?
TimP
You would need to be explicit if you want a specified order of evaluation and short-cutting: if(test1())then if(test2()then ! do something endif endif The way you have written it, without the writes you would have no guarantee whether none, one, or both functions will execute. The presence of side effects (writes) and absence of a specified evaluation order results in both being evaluated, but it looks like you are taking some chances of unexpected behavior. If you are following a C analogy, what you wrote carries some of the flavor of inline int test1(int),test2(int); if(test1() & test2()); // note the single & which doesn't support short-cutting
David_Mccabe
I see, so the evaluation order is determined by the compiler. Procedures with side effects are always evaluated. Procedures without side effects may then be bypassed. Thanks for the prompt reply
It's not that simple. The Fortran language allows the compiler to evaluate any logically equivalent expression, to any degree of completeness and in any order, it finds appropriate. You cannot guarantee which of these functions will be called. Use a nested IF-THEN to force an order.
