hello guys,
when I use ifort -o progrmaname *.f90 , I get an answer :
remark #8291: Recommended relationship between field width 'W' and the number of fractional digits 'D' in this edit descriptor is 'W>=D+7'.
3000 format(i4,4(1x,i2.2),2x,f13.6,i3,4(2x,e18.12))
remark #8290: Recommended relationship between field width 'W' and the number of fractional digits 'D' in this edit descriptor is 'W>=D+3'.
read(fidin,"(3x,i4,4(1x,i2),2x,f10.8,1x,i7)")yr_start,mon_start,dy_start,hr_start,&
has it any influence on my program running? cause I run it well in other platform like WIN7
how can I deal with it?
best regards
PS: i installed Intel Fortran Composer XE 2011 for Linux on my Fedora15 system.
This is an informational message warning you that F10.8 or E18.12 may not be wide enough to express values - especially if there is a negative value. It will have no effect on the running of the program.
Is there a way to turn off this particular warning? We are aware and the warnings get in the way of recognizing other warnings that might be of concern to us.
-diag-disable 8291
