make: ifort: command not found
Runli_L_
I intalled fortran on my linux computer, when trying to intall FPLO, after typing command make, it returned ifort: commmand not found, so I used this code: /opt/intel/composer_xe_2015/bin/compilervars.sh ia32         according to the solutions I found online.
Then it returned
/opt/intel/composer_xe_2015/bin/compilervars.sh: 33: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 34: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 36: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 37: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 38: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 39: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 40: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 41: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 42: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 43: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 44: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 45: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 46: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 47: /opt/intel/composer_xe_2015/mkl/bin/mklvars.sh: typeset: not found
/opt/intel/composer_xe_2015/bin/compilervars.sh: 13: /opt/intel/composer_xe_2015/ipp/bin/ippvars.sh: [[: not found
I am not sure how to solve this problem, is it possible anyone could give me some help on this? Thanks a lot in advance.
The command to use is:
source /opt/intel/composer_xe_2015/bin/compilervars.sh ia32
In some shells, use dot (.) instead of "source", but make sure there is a space after the dot.
Most likely you also want "intel64" instead of "ia32" unless you are on a 32-bit system.
Runli_L_
Thank you so much that worked.
anand_b_
hello,
I have installed Intel fortran parallel_studio_xe_2016_composer_edition_update1ubuntu 14.4 64-bit machine.
Installation went fine, but when i tried to compile a fortran file/ program, i get the message:
ifort: command not found.
I understand that it is related to enviornment/ bash file. i am unable to understand how to define path.  pl help and let me know what changes are required. i have installed intel64
thanks in anticipation
Regards.
See the replies above yours for the general idea. Substitute the 2016 directory name. See the compiler documentation for more on setting up the environment.
