missing /bin/intel64/libintelremotemon.os
Norbert_G_
do anybody know where I can get this file libintelremotemon.os for intel64.
Compiler composer_xe_2013.3.163
For ia32 one was installed, but not for Intel64.
The compiler is looking for and don't work without.
Steven_L_Intel1
I assume you mean .so and not .os. It should be in the compiler install directory bin/intel64 folder. Is the file there? This is the folder with ifort and fortcom in it
Casey
I would try reinstalling the 64 bit compiler.  Barring that you could manually extract it from the installation rpm files using rpm2cpio and cpio.
Norbert_G_
Thanks for help.
Yes it's .so. And this lib is not in the bin/intel64 directory, only in /bin/ia32, but this file don't work as copy in intel64 (It's only 32 bit).  But the compiler find the wrong and make a possible error message. So I know that the path is to the directory is ok.
So for next step I will make a second installation.Maybe that then it will work.
Kindly regards
Norbert
Hausen_H_
I meet similar problem, when execute make -openmp, system return "icc -O2 -xsse2 -c mysecond.c" "icc: error while loading share libraries: libintelremotemon.so: cannot open shared object file: No such file or directory." "make:*** [strem_uni_f_Intel_static.exe] Error 127. How could I fix it?
TimP
You would need PATH and LD_LIBRARY_PATH set as they should be if you source the compilervars script installed along with icc (specify intel64 or ia32) .
