missing finalizer call for array of types
may_ka
Hi all,
I noticed that when arrays of derived types are allocated in an (ordinary) way, no finalization is invoked at deallocation. Here is an example:
Module mod_tmp1
  Type :: tmp1
    Real, allocatable :: a(:,:)
  contains
    Final :: SubFinalizer
  end type tmp1
  Type tmp2
    type(tmp1), allocatable :: x
  end type tmp2
contains
  Subroutine SubFinalizer(this)
    Implicit none
    Type(tmp1), Intent(InOut) :: this
    write(*,*) "finalizer called"
  End Subroutine SubFinalizer
End Module mod_tmp1
Program Test
  use Mod_tmp1
  Type(tmp1), allocatable :: a,b(:)
  type(tmp2), allocatable :: c(:)
  integer :: i
  allocate(a,b(1),c(1))
  allocate(c(1)%x)
  write(*,*) "deallocate a"
  deallocate(a)
  write(*,*) "deallocate b"
  deallocate(b)
  write(*,*) "deallocate c"
  deallocate(c)
End Program Test
with the output
deallocate a
 finalizer called
 deallocate b
 deallocate c
 finalizer called
Is this behavior is observed with ifort 19.04 and gfortran 9.1. I couldn't really find something in standard 2008 which rules out the finalization of "b".
Any idea?
FortranFan
may.ka wrote:
.. I couldn't really find something in standard 2008 which rules out the finalization of "b".
Any idea? ..
The shown implementation(SubFinalizer) in the original post for the 'final' generic only covers the rank-0 (scalar) attribute of an object to be finalized, one has to implement specific procedures for each rank that is to be supported for finalization, or consider the ELEMENTAL attribute for the final subroutine:
module mod_tmp1
   implicit none
   type :: tmp1
      real, allocatable :: a(:,:)
   contains
      final :: SubFinalizer
   end type tmp1
   type tmp2
   end type tmp2
contains
   impure elemental subroutine SubFinalizer(this) !<-- IMPURE only because of WRITE statement in the scope
      type(tmp1), intent(inout) :: this
   end subroutine SubFinalizer
end module mod_tmp1
program Test
   use Mod_tmp1
   type(tmp1), allocatable :: a,b(:)
   integer :: i
   allocate(c(1)%x)
   deallocate(a)
   deallocate(b)
   deallocate(c)
end program Test
Upon execution,
 deallocate a
 finalizer called
 deallocate b
 finalizer called
 deallocate c
 finalizer called
FortranFan
Any idea? ..
module mod_tmp1
   implicit none
   type :: tmp1
   contains
   end type tmp1
   type tmp2
   end type tmp2
contains
end module mod_tmp1
program Test
   use Mod_tmp1
   integer :: i
   allocate(c(1)%x)
   deallocate(a)
   deallocate(b)
   deallocate(c)
end program Test
Upon execution,
 deallocate a
 finalizer called
 deallocate b
 finalizer called
 deallocate c
 finalizer called
may_ka
thanks.
