module interface
mtrover
I'm working with CVF 6.6B and ran across the following error.
module new
type mat_struc
real(kind=4):: M(3,3)
end type
interface mul
module procedure MulLeft, MulRight
end interface
contains
function MulLeft(A,B)
real(kind=4):: MulLeft(3,3), B(3,3)
type(mat_struc):: A
MulLeft = matmul(A%M,B)
end function
function MulRight(B,A)
real(kind=4):: MulRight(3,3), B(3,3)
type(mat_struc):: A
MulRight = matmul(B,A%M)
end function
end module
The interface statement argues that MulLeft and MulRight have the same type, and rank and cannot be used for a generic interface. Obviously, it is ignoring the type and order of the dummy arguments.
Is this error correct for Fortran, or is my code failing some condition?
MikeT
Consider the following program:
type(mat_struct) :: X
real(4) :: Y(3,3), Z(3,3)
Z = Mul(A = X, B = Y)
Which one gets invoked?
The rules for generic disambiguation are complex, but are spelled out clearly in the documentation.
Steve
mtrover
Well, Steve, if it can't figure it out then it can't do non-commutative algebra. The point is, there is a difference in notation, and this notation does indicate a significant difference- MulLeft and MulRight most certainly return different values. If there is no difference between f(a,b) and f(b,a) where a and b are different types, why would the compiler flag an error if you got the order wrong? Since a function is defined by its interface than f(a,b) and g(b,a) where a and b are different types are most certainly different functions because they have a different interface. For instance, you couldn't pass g as the formal argument for the interface of f as a dummy argument.
The compiler complains that the generic is ambiguous because it is - Fortran allows you to use keywords to name the arguments, and since both procedures have an A of the same type and both have a B of the same type, they're potentially ambiguous.
You can fix this by giving the arguments different names in the different procedures. That way there can't be an ambiguity by name.
Steve
mtrover
Thanks, Steve. It took a while to orient my thinking to the problem. It finally filtered through.
My own impression, giving a name to a place-type connection is certainly dangerous, but in this case easy to overcome.
Thanks again.
MikeT
Argument keywords can be very powerful, especially when you have optional arguments. While they may get in the way of generics, for non-generic procedures, they can help clarify the code. I've seen too many routine calls passing 20+ arguments, and counting them can be tedious if you're trying to identify a particular one.
Steve
