newline
sandwich
print *, "123
456"
results in
 123
456
but i want
123
456
how can easily get this, is there a compiler option?
of course i could use
print *, "123", "n456"
but i don't like this.
Isn't that an ugly feature?! -vms will get you what you want. In 8.0, this recognition will be off by default and there will be a new switch to turn it on if you want it.
Steve
sandwich
thanks! (but:)
ugly?: yes. and funny:
program backslash
print *, ""
end program
compiling gives (an error message twice as long as the program):
   program BACKSLASH
print *, ""
Warning 18 at (2:backslash.f90) :  used as an escape character is an extension to standard Fortran 95
Error 5 at (2:backslash.f90) : incomplete string
1 Error
compilation aborted for backslash.f90 (code 1)
i didn't want to use it as an escape character! ;-)
!!! unfortunately this message remains when compiling with -vms !!! ???
i use:
Intel Fortran Compiler for 32-bit applications, Version 7.1   Build 20030701Z
Copyright (C) 1985-2003 Intel Corporation.  All rights reserved.
FOR NON-COMMERCIAL USE ONLY
GNU ld version 2.13.90.0.2 20020802
  Supported emulations:
   elf_i386
   i386linux
   elf_i386_glibc21
TimP
ifc -nbs sandwich.f90
program BACKSLASH
3 Lines Compiled
tim@linux:/windows/E/src/net> ./a.out
Intel Fortran Compiler for 32-bit applications, Version 7.1 Build 20030412Z
elf_i386
i386linux
elf_i386_glibc21
TimP
correction (sorry, cut and paste problem):
GNU ld version 2.11.90.0.29 (with BFD 2.11.90.0.29)
As Tim suggests, add -nbs. This too won't be needed in 8.0. (Grumble - I hate it when Fortran implementors think they're writing a C compiler instead...)
Steve
sandwich
yes, now it works.
thank you both.
yes, i also like C, but i would appreciate that people are able to distinguish.
greetings,
sandwich
sandwich
i have to correct:
as seen in the example below i could not use
print *, "123"
Why not? What happens? It seems to work for me with -vms and -nbs specified.
Steve
sandwich
no, i meant without these options (my first message).
