When the user clicks the 'Restore Down' button, They get a partial view of my modeless dialog controller, See picture1. I have added the vertical scrollbar and will do the horizontal bar later. Right now I need to know what do I do. The pages are directly drawn to the screen. If I tell it to give me say percentages from 1 to 100 and say it sends me 20, do I have to redrae the screen? Are their any good examples of non-qwin apps using scroll bars?
Brooks
链接已复制
Adjusting the drawing area of your chart may be relatively easy to do, but changing the display area of the button boxes may be problematic (unless they consume less than full screen when in full screen mode). You could consider having two modeless dialog boxes, one for the buttons (fixed size) and one for the chart area (resizable).
Jim Dempsey
Thanks Jim,
Don't really know what I'm going to do if anything. I may just force the user to stay maximized or minimize to the tray. Have you seen an app with the modeless control before?
Brooks
I've used such an application before. In my case I'd launched one modeless dialog for a button/slider/spinner box, and one or more additional windows to show charts, graphs, data. I'd used the older Array Visualizer
Jim Dempsey
Here is a code sample showing how to scroll content which is larger than the screen.
SUBROUTINE TabFunc (msg, wParam) IMPLICIT NONE INTEGER(UINT), INTENT(IN) :: msg INTEGER(fWPARAM), INTENT(IN) :: wParam INTEGER :: rval INTEGER(HANDLE) :: hwnd INTEGER(HANDLE) :: hdc_Screen INTEGER, SAVE :: screen_wide, screen_high INTEGER, SAVE :: clientwide, clienthigh ! TYPE T_SCROLLINFO ! SEQUENCE ! integer(UINT) Size ! cbSize knowns UINT ! integer(UINT) Mask ! fMask knowns UINT ! integer(SINT) Min ! nMin knowns int ! integer(SINT) Max ! nMask knowns int ! integer(UINT) Page ! nPage knowns UINT ! integer(SINT) Pos ! nPos knowns int ! integer(SINT) TrackPos ! NTrackPos knowns int ! END TYPE TYPE(T_SCROLLINFO) :: si TYPE(T_RECT) :: clientRect ! the scrollbars are attached to the main window instead of the ! client area of the tab window so that the scrolling messages ! can be seen by MainWndProc() hwnd = ghwndmain ! fullscreen size hdc_screen = GetDC (NULL) screen_wide = GetDeviceCaps (hdc_screen, HORZRES) screen_high = GetDeviceCaps (hdc_screen, VERTRES) rval = ReleaseDC (NULL, hdc_screen) ! PVWindow client size, smaller than fullscreen rval = GetClientRect (ghwndPVWindow, clientRect) clientWide = clientRect%right - clientRect%left clientHigh = clientRect%bottom - clientRect%top ! prepare the ScrollInfo data structure CALL ZeroMemory (LOC(si), SIZEOF(si)) si%Size = SIZEOF(si) si%Min = 0 si%Mask = MOR(SIF_RANGE, SIF_POS, SIF_PAGE) SELECT CASE (msg) CASE (WM_CREATE) xCurrentScroll = 0 yCurrentScroll = 0 si%Max = screen_wide si%Page = clientWide si%Pos = (screen_wide - clientWide)/2 rval = SetScrollInfo (hwnd, SB_HORZ, si, TRUE) si%Max = screen_high si%Page = clientHigh si%Pos = (screen_high - clientHigh)/2 rval = SetScrollInfo (hwnd, SB_VERT, si, TRUE) CASE (WM_HSCROLL, WM_VSCROLL) SELECT CASE (LOWORD(wParam)) CASE (SB_THUMBPOSITION) SELECT CASE (msg) CASE (WM_HSCROLL) xCurrentScroll = HIWORD(wParam) si%Pos = xCurrentScroll si%Max = screen_wide si%Page = clientWide rval = SetScrollInfo (hwnd, SB_HORZ, si, TRUE) xCurrentScroll = xCurrentScroll - (screen_wide - clientWide)/2 CASE (WM_VSCROLL) yCurrentScroll = HIWORD(wParam) si%Pos = yCurrentScroll si%Min = 0 si%Max = screen_high si%Page = clientHigh rval = SetScrollInfo (hwnd, SB_VERT, si, TRUE) yCurrentScroll = yCurrentScroll - (screen_high - clientHigh)/2 END SELECT CALL PVWindowRepaint (-1) ! repaint the window END SELECT END SELECT END SUBROUTINE TabFunc SUBROUTINE ScrollAdjust (ix, iy) IMPLICIT NONE INTEGER, INTENT(INOUT) :: ix, iy ix = ix - xCurrentScroll iy = iy - yCurrentScroll END SUBROUTINE ScrollAdjust
MOR is Paul's own function. for multiple IORs I think. You can use IANY, for example:
wc%style = IANY( [ CS_VREDRAW , CS_HREDRAW, CS_OWNDC] )
IANY can take an array form so you can have as many elements as is required. I find this syntax neat. I think IANY was added in F2008
I (personally) do not understand why the standards committee did not choose to expand a perfectly good IOR intrinsic to accept an array. "any" as used in ANY grammatically conflicts with "any" in IANY. The former stops examining values in the input array upon the first occurrence, the latter does not.
(edit, on second thought, it is not technically in grammatical conflict, rather implementationlly in conflict)
Jim Dempsey
