29285 Discussions
octuple-precision and arbitrary-precision numbers
Tie-Feng_F_
I am using Intel Visual Fortran Compiler for windows.
It only provides  the single-, double-, and quadruple-precision numbers.
But I now need  to perform very accurate  calculations.
Is there any way to obtain, within the  Intel Visual Fortran for windows,
the octuple- and even arbitrary-precision floating-point formats?
Thank you very much for your help!
Tie-Feng Fang
Les_Neilson
Valued Contributor II
(from Google - Fortran arbitrary precision)
You could try this from Professor David Smith of LMU Los Angeles
Also the Fortran wiki here gives a list of various precision libraries.
HTH
Les
rase
Thanks, Les, for the link to the Fortran wiki which I was not aware of until now.
Jeff_Arnold
If you are willing to work with a library which only has a C language interface, investigate MPFR.  See http://www.mpfr.org/  It's a high quality arbitrary-precision math library which produces correctly rounded results.  It is used by many of the compilers in the GNU compiler collection during compilation; it is not required at run-time.
There was a discussion in 2011 on comp.lang.fortran about using MPFR from Fortran.  Seach the newsgroup for the thread titled "arbitrary precision".
I'm not aware that anyone has implemented a Fortran interface to MPFR.
