omp parallel do + omp do should be rejected when compilation time
daichi_f_
The following simple nested OpenMP program(omp parallel do + omp do) can be compiled only with intel compiler.
$ cat test.f90
program test
  implicit none
  integer,parameter :: imax=4, jmax=4
  integer :: i, j
  integer :: n(imax,jmax)
  !$omp parallel do
  do j=1,jmax
     !$omp do
     do i=1,imax
        n(i,j) = 10*i+j
     end do
  end do
  do i=1,imax
     write(6,*) (n(i,j),j=1,jmax)
  end do
  stop
end program test
$ ifort -fopenmp test.f90 && echo ok
ok
Though the compilation finishes successfully, the execution hangs.
$ ./a.out
^Cforrtl: error (69): process interrupted (SIGINT) <-- hang, therefore ctrl+C
Image              PC                Routine            Line        Source
a.out              000000000047F8D1  Unknown               Unknown  Unknown
If I use GNU fortran compiler or PGI compiler, it fails when the compilation time, I think this is the expected behavior.
$ gfortran --version
GNU Fortran (GCC) 5.2.0
Copyright (C) 2015 Free Software Foundation, Inc.
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
$ gfortran -fopenmp test.f90
test.f90:10:0:
      !$omp do
Error: work-sharing region may not be closely nested inside of work-sharing, critical, ordered, master or explicit task region
$ pgfortran --version
pgfortran 16.1-0 64-bit target on x86-64 Linux -tp sandybridge
The Portland Group - PGI Compilers and Tools
Copyright (c) 2016, NVIDIA CORPORATION.  All rights reserved.
$ pgfortran -mp test.f90
PGF90-S-0155-Illegal context for DO (test.f90: 10)
  0 inform,   0 warnings,   1 severes, 0 fatal for test
The code works fine with omp parallel do + omp parallel do for any compiler, this is also expected.
$ diff -pu test.f90 test2.f90
--- test.f90    2017-06-23 16:15:39.000000000 +0900
+++ test2.f90   2017-06-23 16:15:34.000000000 +0900
@@ -7,7 +7,7 @@ program test
   !$omp parallel do
   do j=1,jmax
-     !$omp do
+     !$omp parallel do
      do i=1,imax
         n(i,j) = 10*i+j
      end do
[fukuoka@selene71 1]$ ifort -fopenmp test2.f90 -o test2
[fukuoka@selene71 1]$ ./test2
          11          12          13          14
          21          22          23          24
          31          32          33          34
          41          42          43          44
[fukuoka@selene71 1]$ gfortran -fopenmp test2.f90 -o test2.gfortran
[fukuoka@selene71 1]$ ./test2.gfortran
          11          12          13          14
          21          22          23          24
          31          32          33          34
          41          42          43          44
[fukuoka@selene71 1]$ pgfortran -mp test2.f90 -o test2.pgfortran
[fukuoka@selene71 1]$ ./test2.pgfortran
           11           12           13           14
           21           22           23           24
           31           32           33           34
           41           42           43           44
FORTRAN STOP
So, I think intel compiler should return an error when the compilation time if nested omp parallel do + omp do appears in the code, it is better than the hang.
Best regards.
Daichi
daichi_f_
Here is an additional information for the issue.
icc correctly returns an error when the compilation if nested "omp parallel for" and "omp for" exists in the code.
So, the issue seems ifort specific.
$ cat test.c
#include <stdio.h>
#include <omp.h>
#define IMAX 4
#define JMAX 4
int main(int argc, char **argv)
        int i, j;
        int n[IMAX][JMAX];
        #pragma omp parallel for
        for (i=0; i<IMAX; i++) {
                #pragma omp for
                for (j=0; j<JMAX; j++) {
                        n = 10*i+j;
                        printf("%3d", n);
                        if (j == JMAX-1)
                                printf("\n");
        return 0;
$ icc --version
icc (ICC) 17.0.2 20170213
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
$ icc -fopenmp test.c
test.c(14): error: "for" region may not be closely nested inside a "parallel for" region
                #pragma omp for
compilation aborted for test.c (code 2)
The code works fine with two "omp parallel for", this is expected result.
$ diff -pu test.c test2.c
--- test.c      2017-06-26 08:41:49.000000000 +0900
+++ test2.c     2017-06-26 08:41:22.000000000 +0900
@@ -11,7 +11,7 @@ int main(int argc, char **argv)
-               #pragma omp for
+               #pragma omp parallel for
[fukuoka@selene71 2]$ icc -fopenmp test2.c && echo ok
ok
[fukuoka@selene71 2]$ ./a.out
  0  1  2  3
 10 11 12 13
 20 21 22 23
 30 31 32 33
Daichi
Devorah_H_Intel
Thank you for your report! This issue is better to be reported via our Online Service Center at https://supporttickets.intel.com/
Instructions on how to file a ticket are available here:
https://software.intel.com/en-us/articles/how-to-create-a-support-request-at-online-service-center
Devorah_H_Intel
Daichi,
Thank you for submitting the ticket with this report via Online Service Center.
