oneAPI command line
Rodrigues__Pedro
I started command line from oneAPI prompt and ifort and icl aren't on the path.
Is this an issue(bug)?
Steve_Lionel
To see everything, do a:
set path > path.txt
and attach path.txt to a reply here.
To edit system environment variables in Windows 10, click the Start button, then Settings (gear icon). Click System, then About. Scroll towards the bottom and select Advanced System Settings. Click Environment Variables.
Scroll down to Path under System variables, select it and click Edit.
I don't recommend doing this blindly - you can render your system unusable. Let's see the path.txt from the set command first.
Steve_Lionel
set path > path.txt
Rodrigues__Pedro
I am sending the path on the attached file. I installed the other components from base toolkit. I suppose that everything is fine now.
Steve_Lionel
That looks better. Are you saying it works now?
Rodrigues__Pedro
Yes. I was able to build PETSc library and run all the tests with MKL and MPI.
Thanks for your precious help.
Rodrigues__Pedro
Done. everything works now. Do I have to add any path line to access MKL and MPI 'dll' at runtime?
Developper
Hi , installed oneAPI Base and HPC tool Kit  for Windows. However, we are getting this error oneAPI-cli is not recognized as internal or external command. Please supprot on this. Attached is screenshot as well.
andrew_4619
You should start a new thread not tag an old and not relevant one. Is not cli a Linux tool you said it was a windows install.
Developper
Yes, it is Linux install. Sorry for the error. Can you suggest please further ?
