openmp problem
J__C_
I'm having problems with a derived type variable containing
allocatable components declared shared in an openmp parallel
section. I've attached a minimal code to reproduce the problem
below. It executes when compiled with Ifort versions 11.0, 11.1, 12.0,
12.1, but crashes with 13.0, 13.1, 14.0, partially depending on
optimization flags. I typically get the error message:
forrtl: severe (151): allocatable array is already allocated
even though the print statement tells me it's not. I'm not completely
sure the code complies with the openmp specification, but at least I
cannot see an obvious problem. Any feedback would be appreciated.
All the best,
   John
MODULE DERIVED_TYPE
  IMPLICIT NONE
  TYPE ALLOCATABLE_TYPE
     REAL, DIMENSION(:), ALLOCATABLE :: vector
  END TYPE ALLOCATABLE_TYPE
CONTAINS
  SUBROUTINE INIT(var, len)
    INTEGER,                INTENT(IN)    :: len
    TYPE(ALLOCATABLE_TYPE), INTENT(INOUT) :: var
    PRINT *, ALLOCATED(var%vector)
    ALLOCATE(var%vector(1:len))
  END SUBROUTINE INIT
END MODULE DERIVED_TYPE
PROGRAM TEST
  USE DERIVED_TYPE
  IMPLICIT NONE
  TYPE(ALLOCATABLE_TYPE) :: var
CALL OMP_SET_NUM_THREADS(1)
!$OMP PARALLEL PRIVATE(var)
  CALL INIT(var, 1)
!$OMP END PARALLEL
END PROGRAM TEST
jimdempseyatthecove
Try changing PRIVATE(var) to FIRSTPRIVATE(var).
Reason, you want to copy in the "not allocated" state of var into the parallel region
Jim Dempsey
J__C_
Thanks, Jim, that did the trick!
Best, John
