29430 Discussions
optimization with debug symbols. is that "-g -O3" or "-O3 -g" ?
Rene_S_1
Just wanted to verify what the precedence order is on compiler flags for the intel compilers is.
is the precedence that the last flag specified on the command line the one that wins?
I simply want to generate a binary that optimization level 3 "-O3" but that also includes debug symbols. "-g"
Will "-g -O3" do the trick?
Rene
Kevin_D_Intel
Either order would do the trick. -g implies -O0 but the explicit -O3 overrides the implicit level 0.
You may want/need to include -debug extended. Refer to Debugging and Optimizations in the User Guide for more.
Rene_S_1
Thank you for clearing that up for me and the link to the documentation. Exactly what I was looking for.
Rene
Kevin_D_Intel
You're welcome Rene. Glad to hear that.
jimdempseyatthecove
Kevin,
Then what would -O3 -O0 produce?
The greater of, or last one issued?
What I am getting at is -g may have no implication or effect as to what the optimization level is to be used. (meaning default)
Jim Dempsey
Kevin_D_Intel
Hi Jim,
Here are some details/examples our compiler driver developer provided in the past regarding what we term "left-most/right-most wins", where the idea of left-most and right-most wins is how the command line is interpreted when dealing with options of the same family - or options that can be specified multiple times on the command line.
Here are some examples (same applies to C/C++):
ifort -opt1 -opt2 file.f90
// Above -opt1 and -opt2 are not of the same type or family both -opt1 and -opt2 get set, and ordering has no impact on behavior
// Above -opt1 and -opt2 are of the same type (i.e. -I<dir>)  -opt1 gets precedence over -opt2.  For -I<dir>, -opt1 will be searched first  for headers, then -opt2 will be searched.
// Above -opt1 and -opt2 are of the same family (i.e. -O2, -O3)  -opt2 wins over -opt1.  -opt2 will actually override the behavior the -opt1 behavior.
So -O0 “wins” in the -O3 -O0 scenario.
jimdempseyatthecove
Thanks Kevin,
I was more interested in having this clarified on this forum for others to read. It is best not to have a half answered question....
Thanks for going to an extra effort on your response above.
Jim Dempsey
mecej4
The question regarding -On -g versus -g -On, where n=2, 3, etc., is one that Kevin's classification scheme in #6 does not cover:
where opt1 has the effect of setting some of the switches that opt2 sets. I am not sure how to decide whether two options are of the same type or in the same family, especially when an "umbrella" option such as -g is concerned, or one option implies other (possibly unspecified but default) options. Should one do two passes, expanding umbrella options to "atomic" options in the first pass, and then apply the family/type rules?
Lorri could probably explain better, but as I understand it: options are processed left-to-right. Group options, such as -standard-semantics, make their changes when they appear - individual options can be then changed again further to the right, (I may not have this exactly right - I will ask Lorri to comment.)
Lorri_M_Intel
I'm waving my hands a little bit here (which makes it interesting to type) but ...
Most of the time, options are processed left-to-right.
Some of the exceptions are, as mecj4 notes, ones that I call meta-options that tend to set multiple other options, such as "-fast" or "-standard-semantics".  And yes, individual command line switches from the meta-options can be overwritten by adding the negation of the individual command line *after* the meta-option.
Using -g is yet-another weird exception because, well, it's debug and it's everywhere.  By default, -g sets -O0 if you had not previously already explicitly set a different optimization.
So.  -O3 -g still sets optimization, even though the "-g" happens after the "-O3", and that's why this case works.
There are likely other special cases, but these are what comes to mind right now.
     I hope this helps --
                   --Lorri
