29487 Discussions
Run time checks at the project level vs at the visual studio tools -> options level
Xiao_Cheng_W_
Run time checks e.g.
/check:uninit /check:pointer /check:bounds
can be specified at the project level for each FORTRAN project, or in Visual Studio 2012 in the TOOLS -> Options -> Intel Composer XE -> Visual Fortran -> Compilers -> Default options.
We thought the settings at the project level would overwrite the "Default options" at the TOOLS -> Options level, but after some testing this doesn't seem to be the case, which doesn't seem to make much sense.
Could anyone please confirm that if these run time checks are set in TOOLS -> Options -> Intel Composer XE -> Visual Fortran -> Compilers -> Default options:
then even if the equivalent settings at the project level are set to
/check:nouninit /check:nopointer /check:nobounds
for every Fortran project in the solution
these run time checks are still performed during running?
Thanks!
TimP
Your build log should show options in effect with last one governing in case of conflict.
