29487 Discussions
path length of executable causes a hang
abhimodak
Hi
We are running into the following behavior:
An executable, say, "om" is built into a directory.
I copy this executable into a directory with absolute path such as: /home/eng/abhi/test/bin
Then from a working directory I do: /home/eng/abhi/test/bin/om
The program executes fine.
Next, I copy the same binary executable into a directory with a much longer path such as: /home/eng/abhi/ABCD1234ABCD1234/AnotherTest/bin
Then from the same working directory as previously, I try to run: /home/eng/abhi/ABCD1234ABCD1234/AnotherTest/bin/om
Doing so creates a hang.
Any hints?
Abhi
Juergen_R_R
Valued Contributor II
What does the program do? what is the code?
abhimodak
There is reading of data from a file
Abhi
Juergen_R_R
If the program is reading from a file, did you also copy the file it is reading from together with the binary? Maybe a relative path is specified for that file. It sounds like a reason could be that the program tries to read but cannot find the file and is waiting for input instead.
abhimodak
Hi Juergen
No, the file read from is in the same directory. The program completes everything but hangs as it is existing. That is,
Program OM
! all the program lines
STOP ! hang happens at this STOP statement.
End Program OM
Juergen_R_R
You see this is chasing in the dark without looking at the source code. Another guess is that you never closed the unit for reading and it hangs therefore.
