prerequisites and environment set up for intel ifort
ab1
trying to install ifort version 18.0.1 on ububtu 16.06 pl let me know what are the essential prerequisites for it.
how can i know the name of essentials as i am getting error while building sampling driver,
see /tmp/amplifier_sampling_build_26.03.18.14.13.24.log for details    this says
NOTE: NMI Interrupt Mode is set on 4.13.0-37-generic kernel
  CC   /opt/intel/vtune_amplifier_2018.1.0.535340/sepdk/src/lwpmudrv.o
/opt/intel/vtune_amplifier_2018.1.0.535340/sepdk/src/lwpmudrv.c: In function ‘lwpmudrv_Get_Drv_Setup_Info’:
/opt/intel/vtune_amplifier_2018.1.0.535340/sepdk/src/lwpmudrv.c:4380:9: error: ‘x86_hyper’ undeclared (first use in this function)
     if (x86_hyper && x86_hyper->name) {
/opt/intel/vtune_amplifier_2018.1.0.535340/sepdk/src/lwpmudrv.c:4380:9: note: each undeclared identifier is reported only once for each function it appears in
scripts/Makefile.build:308: recipe for target '/opt/intel/vtune_amplifier_2018.1.0.535340/sepdk/src/lwpmudrv.o' failed
make[2]: *** [/opt/intel/vtune_amplifier_2018.1.0.535340/sepdk/src/lwpmudrv.o] Error 1
Makefile:1550: recipe for target '_module_/opt/intel/vtune_amplifier_2018.1.0.535340/sepdk/src' failed
make[1]: *** [_module_/opt/intel/vtune_amplifier_2018.1.0.535340/sepdk/src] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.13.0-37-generic'
Makefile:224: recipe for target 'default' failed
make: *** [default] Error 2
2   while setting up environment is this this correct way to write in bash file
source /opt/intel/compilers_libraries_2018.1.163/linux/bin/compilervars.sh -arch intel64 -platform linux
3 i want to link threads and shared files too permanently. how can i do it in bash file
ab
ab1
1   pl let me know what are the essential prerequisites for it.
2  i am getting error while building sampling driver,
how serious is this error ... does it mean compilr not installed properly. what should i do to resolve this eror
2 i have set the environment using (working in bash), i am using 64 bit ububtu OS
source /opt/intel/compilers_and_libraries_2018.1.163/linux/bin/compilervars.sh intel64
3 at terminal i type source .bashrc  i get  Illegal variable name
ab
Eugene_E_Intel
Regarding the sampling driver issue, it doesn't seem to be Fortran related.  Please ask for help on VTune forum.
Thank you,
Eugene
