problem installing IntelVisualFortran, integration into VisualStudio
Rasoul_K_
Hi all
This is my first post. I hope I am in the right place. If not, let me know where should I ask for installation problems.
I want to install Intel Visual Fortran 2013. I assume it requires Visual Studio. I downloaded & installed Visual Studio 2010 from Microsoft site which Intel recommended site(http://software.intel.com/en-us/intel-visual-fortran-studio-xe-evaluation). Upon installing IVF13, it says: The Intel(R) Composer XE2013 requires that a Microsoft* development product be installed. Refer to the Release Notes for a list of the required Microsoft* development tools.
If I continue installing, in a window it asks for integration with MS VS but non of choices are selectable. How can I resolve this issue?
I should add that as I don't have enough space in my C: drive, I installed VS in my D: drive and also I want to install IVF13 in D as well. Does it matter?
TimP
You must install the C++ development option of VS2010 in order for ifort to work with it. In principle, VS2010 on D: should work. I expect you mayneed to select an "expert" option when it is offered in ifort installation to get the option to select installation on D:. If you don't have a qualifying version of Visual Studio ifort should offer to install with VS2010 Shell which comes with full (not trial) versions.
Steven_L_Intel1
In your Visual Studio, do Help > About, then Copy Info. Paste the results into a reply here. My guess is that you downloaded an "Express" edition of Visual Studio, which is not supported. However, if you bought Intel Visual Fortran it includes Visual Studio 2010 Shell which is all you need for Fortran development. Be sure to download the installer that includes the shell. If you have an evaluation license, the shell is not available to you. In that case you would need the free 90-day trial of Visual Studio Professional Edition.
Rasoul_K_
Dear Steve The content of info is as follows: Microsoft Visual Studio 2010 Version 10.0.30319.1 RTMRel Microsoft .NET Framework Version 4.0.30319 RTMRel Installed Version: Professional Microsoft Office Developer Tools 01018-532-2002163-70794 Microsoft Office Developer Tools Microsoft Visual F# 2010 01018-532-2002163-70794 Microsoft Visual F# 2010 Microsoft Visual Studio 2010 Team Explorer 01018-532-2002163-70794 Microsoft Visual Studio 2010 Team Explorer I should add that after instaltion of VS2010 Professional, it gave some warning message, but it works. I have attached a screenshot. These issues have took lots of my time and I am really frustrated trying to resolve it. In short sentence, I have a FORTRAN code and I need to do some modification into it and the run it. The only thing I want from VS is the debugging capability. VS is about 3.3 Gb and I don't have fast Internet connection. Also space problem in my laptop has forced me to delete many less-wanted programs. I will highly appreciate if you could kindly tell me a simple way for debugging.
Steven_L_Intel1
You don't have Visual C++ installed - you need that. Did you deselect that when installing VS? DO a "Change/Modify" on VS, select Visual C++ and make sure that the "X64 compiler and tools" subcomponent is selected. Then reinstall Fortran.
Rasoul_K_
Yes I deselect it upon installation as I thought it is not necessary. What a stupid action. Ok I will do as you instruct, but I installed it from Internet. Is Change/Modify of VS could b done offline or it also needs Internet connection? This is my first experience with VS. I searched the menus of VS but couldn't find Change/Modify button/command. Where is it? Sorry for basic question, as I don't have enough knowledge in this field but desperately need to debug a fortran code.
mecej4
Rerun the VS installer and choose Change/Modify, or use the Windows Programs and Features control panel and choose Microsoft Visual Studio and do Change/Modify.
Rasoul_K_
Dear mecej4 Thanks for your reply. I was about to do same when I reviewed what I had done for installation. I think in this case it will need Internet connection. I do remember where I delselected some features. I have to go there again. I will post here what happened and if everything go very well or not. Anyway getting result from a Fortran code was hard for me from long time ago. It is an easy language esp with present advancement and interaction with VS and other stuff. Thanks for your help
Steven_L_Intel1
As far as I know, no Internet connection is needed, as long as you still have the installer available.
Rasoul_K_
What I have downloaded, is as follows: Product Name: Microsoft Visual Studio 2010 Professional - ENU Product Version: 10.0.30319.01 Original file name: vs_proweb.exe Company: Microsoft Corporation Size: 4437 KB Double clicking it, opens a windows which starts to download from Internet. I have attached the windows it shows for download/installation (Please have a look, if it helps you to help me for expedition of the process). It doesn't work without Internet connection. And with slow speed I have, at present more 5 hours has been passed and it is still in its 1/3ed. I think I have to wait for 10 more hours to complete downloading. If you know better way to download so that I can save time, please let me know.
Rasoul_K_
sorry I couldn't upload in previous email. This is the Image I was talking in previous email
Rasoul_K_
Also one more question. As you can see in the top-right side of download/installation windows, it says "Maintenance Mode" What does it mean?
Steven_L_Intel1
Ok - you have the "web installer" which downloads the pieces. Maintenance Mode means you are modifying the existing installation - that's what you want here.
Rasoul_K_
Dear Steve Thanks for your reply. This type of download is extremely slow. Do you know any other alternative? My fear is that after about 15 hours and completion of download it gives another error message and requests for resume of download.
Steven_L_Intel1
Where did you get your copy of Intel Visual Fortran? Is it on DVD or did you download it? The DVD, and some downloads, include Microsoft Visual Studio 2010 Shell so you don't need anything else.
