problem with function returns from c++
jim_cox
Hopefully this should be easy...
I'm using fortran to call a c++ function.
This function returns the value 2 as a long - debugging shows this being set
But when it comes back into my integer4 fortran variable I see the return value as -2147483648
Any thoughts about what might be going wrong?
Very grateful for any assistance.
Arjen_Markus
But does the Fortran compiler "know" that SIDGETLANECT is an integer function?
If you do not declare it as such, via an interface block for instance, the default typing rules kick in an the function will be considered to return a floating-point number.
Try:
interface
    integer function SIDGETLANECT(origin)
           integer, value :: origin
    end function
end interface
or the like
Arjen_Markus
Can you show the code? It is very likely a mismatch in the interface as seen from both sides.
jim_cox
fortran looks like:
INTEGER*4 LNS
LNS = SIDGETLANECT(%val(J2))
c++
long __stdcall SIDGETLANECT(long origin)
    CComPtr<ISIAPILegs> legs = NULL;
    CComPtr<ISIAPILeg> leg = NULL;
    CComPtr<ISIAPILaneApproachs> laneApprs = NULL;
    CComPtr<ISIAPILaneApproach> laneAppr = NULL;
    long b;
    site->get_Legs(&legs);
    legs->get_Count(&b);
    leg = NULL;
    legs->get_Item(long (origin - 1) , &leg);
    if (leg == NULL) return 0;
    else
        long laneApprCount, laneno;
        VARIANT_BOOL laneDisciplineExisting = false;
        leg->get_LaneApproachs(&laneApprs);
        laneApprs->get_Count(&laneApprCount);
        return laneApprCount ;
Arjen_Markus
Try:
interface
    end function
end interface
or the like
jimdempseyatthecove
You should also declare the C++ function as
extern "C" { long SIDGETLANECT(long origin); } // function prototype
See the IVF documentation: C/C++ Naming Conventions.
See also section under BIND
Jim Dempsey
jim_cox
Sorry, its after midnight here and I probably should have also mentioned that
the c++ function is in a separate library
and
that it has a .h function declaration
extern "C" long __stdcall SIDGETLANECT(long origin);
I will take a look at the interface definition in the morning
Thanks for your input
Jim
