29250 Discussions
project type .icproj is not supported by this application
Frank_M
that is the error message I get when I try to open mixed language code (intel c++, and fortran update 7)
Update six works fine.
What am I doing wrong?
Wendy_Doerner__Intel
Valued Contributor I
Did you update both the Intel C and Fortran Compiler to version 7? The compilers go hand and hand with each other. The other thing to check is that you are using the correct compiler and IDE integration for update 7. You can check which compile you are using for Fortran as follows (C++ should be similar):
Tools => Options => Intel Fortran => Compilers => Selected Compiler
and Check the IDE integration in help About in Microsoft Visual Studio.
Wendy
Attaching or including files in a post
Frank_M
I don't know it the system accepted my last message so I will again enter it.
Currently using Intel Visual Fortran Compiler XE on IA-32, version 12.1.0 Package ID: w_fcompxe_2011.6.233
and
Intel C++ Compiler on IA-32, version 12.1.1 Package ID: composer_2011_update7.062 as part of Parallel Studio
on Windows XP and Visual Studio 2008. This set up works.
When I try to install Fortran update 7 I get the above mentioned message.
I tried using the Fortran integration tool. No change.
It looks like you are using Update 6 for Fortran and Update 7 for C++. Can you install w_fcompxe_2011.7.258.exe available at registrationcenter.intel.com? Please let me know if there are error messages during the install.
If you are doing the install and the IDE is not installing this article can help you debug issues:.
Wendy
TimP
I fell into a trap myself when attempting to upgrade ifort and icl to update 7, when I already had updates 5 and 6 installed and running. Only the last installed of ifort and icl from update 7 was available, while the earlier versions remained available. I had to remove updates 6 and 7 entirely (so that only 1 installation of ifort and icl remained) and repeat the full installation of icl and ifort for update 7.
Which version of Visual Studio are you using? In that version, please select Help > About. Click the Copy Info button and paste the result into a reply here.
Frank_M
I try to keep one fortran and one c++ on the machine at a time. When the fortran compiler asks if I want to remove the old version I say yes.
I thought that the c++ compiler removes the old version. The Parallel studio is a clean install of Parallel Studio SP1 with the recent update of the composser (7).
That worked fine with fortran update 6. The issue pops up on the installiation of fortran update 7.
I needed to restore from back-up to again get everything working.
Should I do an un-install of the composer before installing c++ update7 and an uninstall of fortran before installing update 7 ?
Frank_M
Stee, Here is the info you requested. I removed what looked like serial numbers.
Microsoft Visual Studio 2008
Version 9.0.30729.1 SP
Microsoft .NET Framework
Version 3.5 SP1
Installed Edition: Standard
Microsoft Visual Basic 2008
Microsoft Visual C# 2008
Microsoft Visual C++ 2008
Microsoft Visual Web Developer 2008
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB2465361) KB2465361
This hotfix is for Microsoft Visual Studio 2008 Standard Edition - ENU.
If you later install a more recent service pack, this hotfix will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/2465361.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB2538241) KB2538241
For more information, visit http://support.microsoft.com/kb/2538241.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB944899) KB944899
For more information, visit http://support.microsoft.com/kb/944899.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB945282) KB945282
For more information, visit http://support.microsoft.com/kb/945282.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB946040) KB946040
For more information, visit http://support.microsoft.com/kb/946040.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB946308) KB946308
For more information, visit http://support.microsoft.com/kb/946308.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB946344) KB946344
For more information, visit http://support.microsoft.com/kb/946344.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB946581) KB946581
For more information, visit http://support.microsoft.com/kb/946581.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB947173) KB947173
For more information, visit http://support.microsoft.com/kb/947173.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB947540) KB947540
For more information, visit http://support.microsoft.com/kb/947540.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB947789) KB947789
For more information, visit http://support.microsoft.com/kb/947789.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB948127) KB948127
For more information, visit http://support.microsoft.com/kb/948127.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB953256) KB953256
For more information, visit http://support.microsoft.com/kb/953256.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB971091) KB971091
For more information, visit http://support.microsoft.com/kb/971091.
Hotfix for Microsoft Visual Studio 2008 Standard Edition - ENU (KB971092) KB971092
For more information, visit http://support.microsoft.com/kb/971092.
Intel Visual Fortran Package ID: w_fcompxe_2011.6.233
Intel Visual Fortran Composer XE 2011 Update 6 Integration for Microsoft Visual Studio* 2008, 12.1.3514.2008, Copyright (C) 2002-2011 Intel Corporation
* Other names and brands may be claimed as the property of others.
Intel Parallel Advisor 2011 Update 3
Intel Parallel Advisor 2011 Update 3, (build 186618), Copyright 2009-2011 Intel Corporation. All rights reserved.
Intel Parallel Amplifier 2011 Update 5
Intel Parallel Amplifier 2011 Update 5, (build 186533), Copyright 2009-2011 Intel Corporation. All rights reserved.
Intel Parallel Inspector 2011 Update 6
Intel Parallel Inspector 2011 Update 6, (build 186554), Copyright 2008-2011 Intel Corporation. All rights reserved.
Microsoft Visual Studio 2008 Standard Edition - ENU Service Pack 1 (KB945140) KB945140
This service pack is for Microsoft Visual Studio 2008 Standard Edition - ENU.
If you later install a more recent service pack, this service pack will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/945140.
Microsoft Visual Studio 2008 Standard Edition - ENU Service Pack 1 (KB947888) KB947888
For more information, visit http://support.microsoft.com/kb/947888.
Microsoft Visual Studio 2008 Standard Edition - ENU Service Pack 1 (KB948484) KB948484
For more information, visit http://support.microsoft.com/kb/948484.
Security Update for Microsoft Visual Studio 2008 Standard Edition - ENU (KB2251487) KB2251487
This security update is for Microsoft Visual Studio 2008 Standard Edition - ENU.
If you later install a more recent service pack, this security update will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/2251487.
Security Update for Microsoft Visual Studio 2008 Standard Edition - ENU (KB972222) KB972222
For more information, visit http://support.microsoft.com/kb/972222.
Update for Microsoft Visual Studio 2008 Standard Edition - ENU (KB956453) KB956453
This update is for Microsoft Visual Studio 2008 Standard Edition - ENU.
If you later install a more recent service pack, this update will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/956453.
Update for Microsoft Visual Studio 2008 Standard Edition - ENU (KB967143) KB967143
For more information, visit http://support.microsoft.com/kb/967143.
Update for Microsoft Visual Studio 2008 Standard Edition - ENU (KB972221) KB972221
For more information, visit http://support.microsoft.com/kb/972221.
I don't see Intel C++ in the list of installed products.
Frank_M
Neither do I, but its there.
Here is the output from a build after doing a clean.
(this is the working config. with fortran update 6)
1>------ Build started: Project: FLIB, Configuration: Debug Win32 ------
1>Compiling with Intel Visual Fortran Compiler XE 12.1.0.233 [IA-32]...
1>GET_BUFFER_SIZE.f90
1>GET_LAMBDA.f90
1>GET_SARMA.f90
1>POLYMULT.f90
1>Creating library...
1>
1>Build log written to "file://C:\Documents and Settings\fmassie\My Documents\Visual Studio 2008\Projects\TSEx\Lib2\Debug\BuildLog.htm"
1>FLIB - 0 error(s), 0 warning(s)
2>------ Build started: Project: TSEx, Configuration: Debug Win32 ------
2>Performing Custom Build Step (Microsoft VC++ Environment)
2>Compiling with Intel C++ Compiler 12.1.1.062 [IA-32]... (Intel C++ Environment)
2>utility_procs.cpp
2>uni_arma_procs.cpp
2>uni_analysis_procs.cpp
2>TSExtm.cpp
2>TSEx.cpp
2>Linking... (Intel C++ Environment)
2>xilink: executing 'link'
2>Embedding manifest... (Microsoft VC++ Environment)
2>Build log was saved at "file://C:\Documents and Settings\fmassie\My Documents\Visual Studio 2008\Projects\TSEx\TSEx\Debug\BuildLog.htm"
2>TSEx - 0 error(s), 0 warning(s), 0 remark(s)
========== Build: 2 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
I'm going to try doing a reinstall of the Parallel studio and see if that makes any difference.
Yes, a reinstall with current versions of Intel C++ and Intel Fortran would be a good thing to do.
Frank_M
Results of removing and re-installing everything. (No hotfix)
Version 3.5 SP1
Still no c++ after completely removing all intel software products and re-installing Parallel Studio SP1
________________________________________________________________________________________________
Version 3.5 SP1
After the installing Parallel Composer Update 7, c++ is still not shown.
__________________________________________________________________________________________________
Version 3.5 SP1
Intel Visual Fortran Package ID: w_fcompxe_2011.7.258
Intel Visual Fortran Composer XE 2011 Update 7 Integration for Microsoft Visual Studio* 2008, 12.1.3518.2008, Copyright (C) 2002-2011 Intel Corporation
When installing Fortran Update 7 I got the message
Intel Parallel Debugger Extension is already installed
If you proceed, the existing Intel Parallel Debugger Extension will be uninstalled and replaced with the verson from Inter Composer XE 2011.
________________________________________________________________________________________________________
The origial error is still occuring. What now?
Frank_M
I've gone ahead and reported this as an issue to primer support.
Frank_M
I found a solution.
Step 1) Take Parallel Studio 2011 and Fortran XE both back to update 6.
Step 2) Install Fortran XE update 7.
Step 3) Install Parallel Studio 2011 updat 7.
I don't know why it should make a difference if Paralle Studio 2011 update 7 is installed first, but it does.
