Using VS 2005 and Intel Fortran 10.1, I'm trying to use "C" as a comment line indicator. The Intel Fortran help says that I can, however in the Visual Studio IDE doesn't allow it to. I enter "C" in the first column of a line and none of the text after it is considered a comment. If I use "!" it works.
Any ideas? Do I have to change a setting?
NEVER MIND: Found the answer. have to use ".f" vs. ".f90"
