"Stack trace terminated abnormally" due to symlink
Halvor_L_
I have encountered a strange issue with tracebackqq in combination with symlinks, which causes the stack trace to terminate abnormally.
Consider a file tracebacktest.f90:
program tracebacktest
  use ifcore, only: tracebackqq
  call tracebackqq()
end program tracebacktest
which is compiled and run as follows:
ifort -traceback tracebacktest.f90 -o tracebacktest/a.out
ln -s tracebacktest/a.out test
./test
This causes a "Stack trace terminated abnormally". Similarly, if the symlink is in the same folder, the Routine/Line/Source columns only list "Unknown":
ifort -traceback tracebacktest.f90 -o a.out
ln -s a.out test
./test
I'm guessing this is a compiler issue, but please correct me if it is due to incorrect use of symlinks. I'm using ifort version 16.0.2 on Linux .
Steven_L_Intel1
I can reproduce this. My guess is that the traceback code, which needs to read the executable file, is having trouble with the symlink. I will pass this on to the developers and let you know of any news. Issue ID is DPD200409564.
Steven_L_Intel1
I expect this to be fixed in Update 4.
