"indirect" linked lists
forall
Is the following construct legal in Fortran-95?
type parCompObjType
type(dparType),pointer::par(:) ! parameters
endtype parCompObjType
type dparType
type(parCompObjType)::ftran_v2z
endtype dparType
This seems to compile and execute.
But if I switch the order of declarations (which seem symmetric, except for the dimension statement), the compiler complains...
type dparType
endtype dparType
type parCompObjType
error #6457: This derived type name has not been declared. [PARCOMPOBJTYPE]
Using (a more complex form of) this type of "indirect" linked list would allow me to simplify some of my code very dramatically, and it works on a simplified pilot code, but I am a little hesitant if this could create standard-compliance problems, or have some other problems I might be unaware of ...
could somebody shed some light on this?
thanks in advance.. dmitri
Steven_L_Intel1
Your first code is legal Fortran 95 and the current version of Intel Visual Fortran compiles it successfully. Which version are you using?
The key is the POINTER attribute. With that, the type can be "any accessible type". Without it, the type must be previously defined.
forall
thanks Steve.
Indeed the first code compiles and runs correctly, and the second returns an error - which confused me a bit.
I just wasnt sure if this was some kind of extension. But your explanation re the POINTER made it clear (if somewhat esoteric - eg, why not allow for any accesible type whether or not a component is a POINTER?).
I am still on Intel Fortran 11.0.072. Will be upgrading to VS2010 soon and to the latest 11.X compiler.. before taking the plunge on the new Intel 12 compiler!
dmitri
Steven_L_Intel1
Sorry, I tested the wrong one. Yes, the second case is not legal Fortran and the compiler correctly complains.
mecej4
Often, one needs to define a type which includes as a component pointers to other variables of the type being defined (the phrase "self-referential" is sometimes used as a label for such types).
Consider, for example, a binary tree where each node contains a five-character word, and is defined thus:
[fortran]type tnode
  type (tnode), pointer :: left=>null(),right=>null()
  character(len=5),pointer :: name=>null()
  integer :: count=1
end type tnode
[/fortran]
Compiling code that contains recursive definitions is hard for compilers to do, but if only pointers are used (and if pointers to any objects have the same footprint) it is not so hard.
You could think of the permitting of pointers to be used this way as an invaluable loophole without which many programs would be much more difficult to write.
