randn() in Fortran
yingwu
Hi, I am back again. Is there any function to implement the randn() in Fortran? Or I need to use MKL for this. Thanks very much.
Ying
Jugoslav_Dujic
Valued Contributor II
Quoting - yingwu
Ying
There are several routines at:
http://users.bigpond.net.au/amiller/random.html
I wasn't aware that MKL contains an appropriate routine -- does it? If it does, what's wrong with using it?
Jugoslav_Dujic
Quoting - yingwu
Ying
yingwu
vsrnggaussian
Quoting - Jugoslav Dujic
Hi, yes, The MKL supports this. In matlab, randn() generates Normally distributed pseudorandom numbers, which is standard normal distribution. In fact, it is a special Gaussian distribution. So using vsrnggaussian() from MKL is OK, but we need to specify the mean is 0 and deviation is 1.
I know why there is no randn() in IVF. It is reasonable.....
IVF itself provides uniform random number generators only. The one in the standard intrinsic RANDOM_NUMBER is the one I would recommend. If you have other distribution requirements, you'll need to find another library, such as MKL, that has what you want.
yingwu
Yes, Steve, I agree with this. The MKL is good enough to do this.
I just switch from matlab to fortran, so I need some time and help to be used to Fortran. But anyway, it is not difficult. The matlab provides a rich set of functions to use, which is the same as IVF with MKL or IMSL.
anthonyrichards
New Contributor III
Here is a simple program to generate real numbers having a Guassian distribution with standard deviation SIGMA. It uses standard routines to generate a pseudorandom sequence of numbers uniform in the range 0 to 1.
! PROGRAM: gaussianrand
! PURPOSE: generate gaussian random numbers with given sigma
! Uses FUNCTION RAND(0) to generate uniform random numbers
! between 0 and 1, and ROUTINE SEED to set the seed
! Uses the Box-Muller algorithm to generate numbers with
! a Gaussian distribution of probability.
program gaussianrand
implicit none
integer,parameter:: nrand=1000000
REAL*8 UNIF1(nrand), UNIF2(nrand)
REAL*8 Y1,Y2,SIGMA,binsize, binhalf
INTEGER I,nbins, bins(201),ix
! supply seed to get the same pseudorandom sequence each time
! program is run. To get a different sequence, change the seed
! by calling SEED with a different integer value.
call seed(1)
! set the sigma value you want
SIGMA=2
! get the random numbers. RGAUSS returns two gaussian random numbers
! from the same distribution for each call.
DO I=1,NRAND
CALL RGAUSS(SIGMA,Y1,Y2)
UNIF1(I)=Y1
UNIF2(I)=Y2
END DO
! After this loop, there are NRAND values in each array UNIF1 and UNIF2, each with
! a Gaussian distribution with standard deviation SIGMA
! To display the resultsfor UNIF1, bin the results usingbin size=0.05*sigma
nbins=201
binsize=0.05*sigma
binhalf=0.5*binsize
do i=1,nrand
! compute which bineach number goes into
ix=101+floor((UNIF1(i)+binhalf)/binsize)
if(ix.gt.0.and.ix.lt.201) bins(ix)=bins(ix)+1
end do
! save the numbers in each bin to display later
open(unit=10,file='rgauss.dat',form='formatted',status='unknown')
write(10,1000) (bins(i),i=1,201)
1000 format(10i8)
close(10)
end program gaussianrand
subroutine rgauss(sigma, y1,y2)
real*8 x1, x2, w, y1, y2, sigma
do while ( (w .ge. 1.0).or.(w.eq.0) )
x1 = 2.0 * rand(0) - 1.0
x2 = 2.0 * rand(0) - 1.0
w = x1 * x1 + x2 * x2
end do
w = sigma*sqrt( (-2.0 * log( w ) ) / w )
y1 = x1 * w
y2 = x2 * w
end subroutine rgauss
