I was part of the beta program for the intel 2017 compiler. Everything worked fine. We just updated to the official release and i have a new issue with the message :
(.text+0x51): relocation truncated to fit: R_X86_64_32 against symbol `mod_parallel_defs_mp_comm_' defined in COMMON section in avbp.a(mod_parallel_defs.o)
the avbp.a file is an archive we generate ourself from .o files with the ar r command … I have seen in the forum that switching to dynamic libraries might solve the issue ( ticket from 2011 ) but this is not a librarie juste an archive to avoid having a very large linking command that fails on some systems ( we have a lot of files .. )
Any suggestions ? Why did the behavior change between the beta and the release ?
We have this issue on a KNL system.
thank you
The linkage error was caused by over 2 GB of static data in the library. Please try to recompile the library and application with option "-mcmodel medium" or "-mcmodel large".
Xiaoping Duan
Intel Customer Support
Hi , thank you for the info.
Indeed it seems to solve the problem. Please note that the intel 2017 beta ( 2017.0.064 ) did not have this requirement but the release ( 2017.0.098 ) does.
![](/skins/images/06022F5BB6D2F28C8F102671A0F06E85/responsive_peak/images/icon_anonymous_message.png)
